I was hoping you guys could chime in on if I should go bulk charge or balance, maybe let me know if I'm completely wrong on something, it's my first pack.
quick backstory, I ride a gio pb710, with 48v12ah old saggy sla batteries. I'm definitely on board with lithium.
Looking now at getting 4 6s zippy 5000mah packs to make a 12s 44.4v/50.4v 10Ah pack.
these... http://www.hobbyking.com/hobbyking/store/__8582__ZIPPY_Flightmax_5000mAh_6S1P_20C.html
Here is where I'm at with a bulk charging set up;
first I'd need to wire in this BMS http://www.batterysupports.com/44v-48v-504v-12s-30a-12x-36v-lithium-ion-lipolymer-battery-bms-p-268.html
then use this charger http://www.batterysupports.com/432v-44v-504v-4a-lithium-ion-lipo-battery-charger-12s-12x-36v-p-167.html
or a balance charger and parallel charging board like this http://hobbyking.com/hobbyking/store/__53601__HobbyKing_8482_X200_AC_DC_Touch_Screen_Smart_Battery_Charger_10A_6S_US_Plug_.html
http://www.hobbyking.com/hobbyking/store/__14856__Hobbyking_Parallel_charging_Board_for_6_packs_2_6S_XT_60_.html
The way I see it both have pros and cons, bulk charging is easier, the bms pack would probably end up being built to stay permanently together, clean and neat.
balance charging would mean breaking the pack down every time, but I feel parallel charging at less than 1/2C is very good for the batteries, but then would I need a BMS or something anyways for riding (low voltage cutoff) or do I need to monitor voltage on the road with an accurate digital display meter?
