Nice bike. Serviceable battery, and fully accessorised with everything you need for year round riding.
No handlebar display?
Some experts will chime in to help you, and, if they have no direct experience with this specific bike, will likely want to know what controller it’s running.
The controller is likely enclosed in the boxy looking chamber lump behind/under the bottom bracket.
There’ll be a label on it that hopefully is the original manufacturer’s, and is hopefully facing toward the ground so that you can easily read it.
If either of those conditions is untrue, you might be required to rotate the controller to view the label, and, if Velectrix have relabelled the controller, even open it to see the manufacturer labelling on the PCB.
Worst case you simply (sic?) need to swap the controller for a different one. They only cost tens of dollars, although it can be bothersome to adapt plug and socket wiring to compatibiliise them.
