so now i'm using tektro rear disc-brake from ilia and magura mt2 for the front, but it still feels the stopping power is not enough
the rear rotor is 165 mm cause the guy who installed it said that 203 mm may cause deformation in the frame but i'm still gonna try http://www.jensonusa.com/Shimano-SM-RT81-XT-Ice-Tech-Rotor (i have alfine 11) see if that helps
i'm also gonna try to switch pads http://www.jensonusa.com/Magura-MT-Performance-71-Brake-Pads i'm not sure what will go with the tektro, so i'll try this http://www.jensonusa.com/Brake-Pads/Swiss-Stop-Sintered-Shimano-Disc-Pads
the reason i wanted a magura in the front was becouse it also uses the same mineral oil as the tektro, as tektro is only hydraulic e-brake available aside from hygia which not only can't exactly be found but also uses mineral oil (as opposed to some claims here about dot oil) , i can't even be sure about which mineral oil , because i understand that for example shimano's mineral oil won't be good for magura as it's not the same viscosity.
another option i read here was to use this, but it seems it also needs mineral (probably the same type as magura itself uses)
http://www.hibike.com/shop/product/pd897c030ae9484fb91d5aea4278c224f/Magura-pressure-switch-for-E-bike-for-all-rim-and-disc-brakes-Schliesser.html
