fabieville
- Joined
- Jul 15, 2012
- Messages
- 114
I saw a Powerhouse Lithium 24V Battery rated at 200ah and weighs just 7.5kg.
What I want to know is if this battery would be suited to use on a e-bike,seeing that it is not lifepo4. Also would I get the same or similar performance from it as with a lifepo4? You can go to the below link and tell me what you think.
If it performs less than a lifepo4 in terms of amp hour seeing that the lithium is rated at 200ah what lifepo4 ah would that match up with?
http://www.ebay.co.uk/itm/261855680662?ssPageName=STRK%3AMEBIDX%3AIT&fromMakeTrack=true
Designed especially to fit within the battery bay of the Powerhouse Pro range of single seat Golf buggies and any other golf buggy using 24V (2 battery system)
It weighs in at 7.5kg and measures (W)160mm x (L)250mm x (H)200mm (6.25" x 10" x 8"), As there is only one lithium battery required the weight saving when compared to two 80ah lead acid batteries is a massive 45kg or around 9 stone.
The Lithium Battery is supplied fully protected by a sophisticated specially designed battery management system that constantly monitors every cell to ensure the lithium battery is always optimised for best performance and life Also supplied with its own lithium charger.
Charging is also quicker, a flat battery will charge in around 8hrs
The 18 Hole Lithium Golf Buggy Battery can also be used on all makes and models of single seat buggies using a 24V system.
Simple modification to wiring is required. (Supplied)
Remember you only need 1 battery. It replaces the 2 standard lead acid batteries on your buggy.
Model: Powerhouse Lithium 24V Battery
Capacity: 24v Equivalent to 2 x 76Ah lead acid batteries 27Holes
Type: Lithium
Weight: 7.5kg
Size: (W)160mm x (L)250mm x (H)200mm (6.25" x 10" x 8")
Applications: Suitable for use with the Powerhouse Golf buggies.
Life expectancy*: in access of 1000 Cycles, unconditional.
Duration: 18+ hole capacity depending on terrain and conditions.
Features: Ultra Light High performance. Complete with Lithium Charger
Warranty: This battery comes 2 years manufacturers guarantee (limited warranty).
Usage: Can be used anyway around as it is non spilable. Must be stored in charged condition
Suitable for many other makes of buggy inc:
Powerhouse Golf
Powakaddy
Electrocart
Patterson
Pennine
Type: Lithium
Weight: 7.5kg
Powerhouse Golf
Powakaddy
Electrocart
Patterson
Pennine
