bruce.nali
10 µW
Been learning from ES as a lurker for a bit so first thanks to all who give info here. I have just received a new 36v, 15ah battery from Ping. Ordering and delivery was great as was packaging. This is a replacement for my original ezee front hub kit battery that worked well for about 5 yrs. I didn't push it too much, mostly used for a 10 mile commute and city cruising pretty consistently all year, and left it on the charger whenever not in use. So I think I have a 20amp controller and 400 watt motor. I was not looking for added speed but just a little longer distance and long life (without too much extra weight. Also will add a cycle_analyst.
so the questions:
1. I will give the battery a harder shell as recommended and would like to mount on top of my standard rack in a custom case. Fit would be better if the battery was laid on its side, i.e. now the top with the BMS is the narrow face, I would like to make the top and bottom the wide face. Any problems with this on a pouch cell battery? Also would it be ok to move the BMS so it was on the wide face (take off the wrap and just move it?).
2. I am somewhat confused over the various discussions regarding an on/off switch and need for some kind of spark suppressor for connecting battery to controller. With just 36v are these needed or desirable? My controller has anderson connectors so I will be adding them to the battery output wires and I can solder, etc if putting a switch or suppressor would extend the life of the battery.
3. I have always just left my charger on, and the battery switch on with the old battery. Should I now put a timer on the charger to shut it off? If so do I just figure the time from when the BMS lights usually all go on, or what?
thanks in advance and I will post some pics of my new battery holder when done.
so the questions:
