good morning friends of good lights
I can't find the mxus 3k 6t experience on the big wheel ( 2.15 meters )
I can't not find this motor in the simulator
my project is low cost. I have pictures
rear wheel : 21" motorcycle tire 300-21 with 2,15 meters of circumference
front wheel : 21" motorcycle tire 275-21 with 2,10 meters of circumference
controller : hksunwin controller with irfb4110 fets with 24s li-ion at 4,1v per cell ( https://endless-sphere.com/forums/viewtopic.php?f=2&t=71128&start=450 )
bms : aliexpress rjxzs tipical bms led, nominal 60A / peak 180A (14 fets hy3712p )
battery: 24s li-ion ( bak c4 cells ) 12p24s
motor : 3k turbo
volt: nominal 88,8v
amps: ? limited off cells and motor ?
low front and up rear bicycle - is there danger in this?
steel structure. without suspension. to stay light and lown cost
maximum amps for the motor in these conditions? with hole and without statorade
I speculate 80 amps in my controller with 18 fets irfb4110
I do not know limited amps of may laptop battery in datasheet is 2c , 4,4a
in practice my cell bak c4 can work with 8 amps . I'm not sure . sorry
my control panel is 100v , 100A , has a thermometer 100 degrees . he is Juntek vat1100
Thanks for the comments ! Matheus
motor : 3k turbo
volt: nominal 88,8v
