Hey there all,
Been reading a shit-ton of info about boards over the last few months and think I'm finally ready to pull the trigger on some parts. I was hoping you all could give me your input. I'm 6ft. and weigh 185. I live in the bay area and am looking for something that will top out around ~25mph and take me up some hills. Nothing crazy, just mellow grades. I thought I'd start with a single motor high-powered setup, then maybe upgrade to dual down the road. I don't need really long range but I'd like to get about 10 miles minimum. Also, it can be a bit wet around here. Any recommendations for waterproof cases that will fit the ESC/batteries? Do I need to worry about overheating with something like that?
Parts List:
Deck: Generic blank deck from eBay with a small kick tail. 40" L x 9.75" W
http://www.ebay.com/itm/New-Black-Longboards-Kicktail-Skateboard-Deck-40-X-10-/390304274796?hash=item5adff2996c:m:mTrhsIe-Xo1qzk1drXZcT6A
Mount and power: DIYElectrickskateboards complete single motor 12s kit
http://diyelectricskateboard.com/product/complete-2200w-single-motor-electric-skateboard-kit/
Batteries: QTY. 4 - ZIPPY Flightmax 5000mAh 3S1P 20C. Looks like HobbyKing is back-ordered, though I saw them on eBay in "new" condition. Safe bet or no?
Battery charger: HobbyKing™ ECO6-10 200W 10A 6S Bal/Dis/Cyc Charger w/ acc.
http://www.hobbyking.com/hobbyking/store/uh_viewItem.asp?idProduct=70748
Power supply: HobbyKing 350w 25A Power Supply (100v~120v)
http://www.hobbyking.com/hobbyking/store/uh_viewItem.asp?idProduct=70998
Parallel charging board: HobbyKing Parallel charging Board for 6 packs 2~6S (XT-60)
http://www.hobbyking.com/hobbyking/store/uh_viewItem.asp?idProduct=36907
Transmitter: Wii Kama Wireless Controller
http://www.amazon.com/Wii-Kama-Wireless-Controller-Colours-Nintendo/dp/B0012R58LG
I plugged in the numbers to the calculator I found here: http://toddy616.blogspot.com/2013/07/electric-skateboard-calculator.html
LiPo Cells: 12
Motor kV: 200
Efficiency: 70% (used his recommended number)
Gearing: 20Tx44T = ratio of 2.20:1 (based on the last availability I read about from DIYelectricSkateboards)
Wheel Size: 83mm
Gives me a battery voltage of 44.4v
Motor RPM: 8880
Weighted motor RPM: 6216
Top Speed: 39.24 mph
Weighted Top Speed: 27.47mph
Any suggestions or substitutions? I know the iCharger would be nice, but I was thinking I could upgrade down the road and use the HobbyKing one at work eventually.
Thanks for any and all input, I'm totally overwhelmed at the amount of info on here!
Parts List:
LiPo Cells: 12
Motor kV: 200
Wheel Size: 83mm
Motor RPM: 8880
