Just_Ed
I got one of those unsolicited 'we found something you might be interested in', emails from Amazon. Usually, I just delete them, but this one did catch my eye, because of the potential for using it with my RV.
Any RV'ers out there using anything like this?
https://www.amazon.com/gp/product/B003TU6MDM?ref=em_1p_4_ti&ref_=pe_27541410_481156210
I went through a number of the reviews, and did find one that was using a 10000 watt version, with no stated problems.
So in a pinch, or if we wanted to dry camp....
If it's possible, then I will delve into the specs more, to see what I can 'learn'
From what I read, I would need a dc-dc converter, to bring it down to 12 volts nominal.
Q. Can I use the above inverter, with my 48 volt battery pack ?
https://www.techdirectclub.com/48-volt-nissan-leaf-lithium-ion-mini-power-pack-battery-3-5-kwh-66ah-g2/
Q. If so, just how long can I expect my BP to last before needing a recharge.
( I know this is a very subjective question, and hard to answer without more detail).
The best I know to say, is during any of our trips, using 30 Amp, shore power, we only use our lights, TV, microwave. We use the 120 volt outlets for the coffee pot, small fan, laptop/phone chargers, and only the occasional 1500 watt heater, for a short time.
My A/C unit is 12000 BTU's.
The fridge and water heater as well, but they can both run on propane.
Also the 1500 watt heater is more for spot heat. We can use the propane heater for whole house heat.
Thanks for any feedback
Ed
Ed
