MitchJi
Hi,
How do these front disc brake options compare in power, and how difficult (universal) are they to implement?:
http://www.bikesonline.com/hayes-v-9-kit-disc-brake-rotor-224mm.htmrecumpence said:At this point I installed a MRP fork (White Brothers), 224mm Hayes front rotor...
http://greyborgusa.com/dnm-dual-disc-brake-fork/9" oversized disc rotor and adapter kits for specific DH fork applications
All kits designed for Hayes 74mm post-mount calipers
(IS-TA) International-Standard 20x110mm thru-axle dropouts (requires thicker adapter than quick-release dropout fork)
(PM) 74mm Post-Mount for either 6" or 8" stock rotors (without adapters)
Includes: 9" (224mm) 6-bolt/44mm-BCD rotor and fork-specific adapter bracket
http://www.mopedarmy.com/wiki/Puch_MagnumThis is the recommended fork which is used on the Greyborg Warp series of frames. They are also available for purchase separately. They have been custom made by DNM for Greyborg to accept dual front calipers and are supplied with a high quality dual disc 36 hole front hub
There are many different customizations of Puch Magnums:
Honda MB5 front ends and wheels make for a bigger, heavier bike, but allows for disc brakes, increased stability at speed and a very different look
