bmwupgrade
100 µW
- Joined
- Jun 13, 2021
- Messages
- 9
So I'm in the planning stage of building new pack and time to prep space for BMS. I have VESC controller, which controls discharge, so technically discharge control is not even that much needed, but seems like space allows, so why not... or am I missing some Charge Only BMS benefits over FULL BMS?
I don't find any VESC compatible full BMS on the market at anything under ridiculous amount of money, but also not much needed.. Just need to be able to configure BMS the way I want and check thee condition later on, so BT is perfect.
AliExpress seems like it is full of options but in reality it is only few. here is what I have compiled in 16s 60a capable with 80a at most:
- AntBMS 16s 80-150a charge/discharge 70 x101mm 49usd (BT built in, iOS app, too big temp sensors) https://www.aliexpress.com/item/4001202028077.html
- jk-bd6a17s6p 60-120a charge/discharge 80 x110mm 68usd (BT build in, IOS app. 32usd GPS + 4G with Cloud service!! good temp sensor )https://www.aliexpress.com/item/1005001315915241.html
- Daly Smart BMS 16s 60-180a charge/discharge 65 x100mm 72usd (IOS app, BT incl, good temp sensor) https://www.aliexpress.com/item/1005001803913333.html
- JBD li-ion 16s 100-120a charge/discharge 120 x 145 (BT / uart not incl, iOS app monitor only/no control, good temp sensor) https://www.aliexpress.com/item/1005001831386283.html
- ENNOID 18s BMS SS 100a charge/discharge 60 x100mm 200usd (Can for VESC) https://www.ennoid.me/bms/ss
new edit - Tiny BMS s516 - 150A charge/discharge 65 x105mm 200euro+VAT (BT built in, Can for VESC)
________________________________
While typing I did alot of research and now we have a list with some important compare points! Am I missing any good BMS in here? please advice if so OR if you have had ANY experience with any of those BMS!
