Audisport09
Hello, I was wondering if someone could help me. It took me a while to figure out what was causing my random hall issues. I thought I might have faulty motor.
When I charge my Lipo battery whilst it’s connected to the controller the controller tends to go into hall, not every time, but most of the time. The hall fault is guaranteed if I turn it on and touch the throttle whilst it’s plugged into the charger. If I reset ignition, the throttle works for like a split second and then goes straight back in to hall fault. It takes several hours with the battery disconnected to get the bike to work again.
Anyone know what could be going on? Bad controller? Anyone with a sabvoton ever run it with charger plugged in? Is it harmful to do so?
I obviously stopped charging the battery whilst they are connected to the bike and went almost 2000 miles hall fault free until recently when I forgot to disconnect the battery out. Sure enough 13 flashes hall fault.
Battery: 18s
Charger: Meanwell HGL-600H-24A
Battery: 18s
