markz
100 TW
Was surfing the web trying to find Yukon Trail SM24 Navigator retails for. Ran across sears sale. FYI on the website the first price has a line through it, original price, second price is sale price.
Checking out reveals only USA addresses and FREE SHIPPING!!!!!!!!!!!!!!!!!!!!!!!!
I punched in a Seattle Zipcode.
It states Sold by Aplusbuy, so I dont know what that means. I thought it was the SEARS website online and not some Amazon thingy. Still not bad at all, get free shipping to boot.
http://www.sears.com/search=ebike
All prices would be in USD, but $200 to $250 aint bad, looks similar to Yescomusa. All are fronts except one.
There are more pages, and more kits available, click on the Next page of Results. Came across 2 more kits.
One was a
$338.90$207.99
AplusBuy 36V 500W 26" Rear Wheel Electric Bicycle Motor Engine Kit E-Bike
$475.90$259.99
AplusBuy 48V 1000W 26" Front Wheel Electric Bicycle Motor EBike Conversion Kit
$441.90$239.99
AplusBuy 48V 1000W 20" Front Wheel Electric Bicycle Motor EBike Conversion Kit
$365.90$214.99
AplusBuy 36V 750W Front Fat Tire Electric Bicycle eBike Conversion Kit 24"/4" Width
$382.90$214.99
AplusBuy 36V 750W Front Fat Tire Electric Bicycle eBike Conversion Kit 20"/4" Width Rim
$369.90$209.99
AplusBuy 48V 1000W 26" Front Wheel Electric Bicycle Motor Engine Kit E-Bike Cycling Hub Conversion
$369.90$209.99
$338.90$207.99
AplusBuy 36V 500W 26" Front Wheel Electric Bicycle Motor Engine Kit E-Bike
This is for the one rear kit they have, which is a Direct Drive I believe
I would buy this if they shipped to Canada, maybe I will try emailing the seller.
One was a
$369.90$229.99
AplusBuy 48V 1000W 26" Rear Wheel Electric Bicycle Motor Engine Kit E-Bike
$354.90$207.99
AplusBuy 36V 800W 26" Rear Wheel Electric Bicycle Motor Engine Kit E-Bike
also of note a lithium battery
$509.90$442.99
AplusBuy 14AH Battery Lithium Rear Rack for 48V1000W Electric Ebike
$338.90$207.99
$475.90$259.99
$441.90$239.99
$365.90$214.99
$382.90$214.99
$369.90$209.99
$369.90$209.99
$338.90$207.99
Description Item # SPM8999575224 Model # 19EBE001-36V500D-26R
Package Includes:
Powerful 500W 36V brushless hub motor
26" rear wheel (the whole wheel with tire!)
2 brake pullers
Electric controller
Thumb gear changer with battery power indicator
Battery power indicator
2ea. handlebar grips
Rubber connecting harness (color will pick at random)
Battery and Charger are Not Included
Special: Comes with upgraded battery carrying bag and end bracket for FREE
Upgrade:
Dual Mode Controller: Motor works under Hall effect and non-Hall effect, extend life for electric bike
(For 1 mode controller, the motor only work under hall effect, if hall components inside the motor break down, the motor will stop working. But with our controller if the components break down, it'll switch into non-hall effect mode, the motor will still be working.)
Features:
Approx. 25 KPH top speed
Provides you with a whole wheel with tire, not just the tire frame Takes less than hour to install
The kit includes motorized wheel, motor controller, battery charger, thumb throttle, power break lever, wire harness
Quiet and reliable brushless gearless hub motor
Motor specifications: 36v / 500w / 293rpm
High motor efficiency: >80%
Motor diameter: 245mm
Wheel size:26"*1.75"
Reinforced 32mm rim and 40mm tire
Drive system has no moving chains or gears, no friction, more efficient, less chance to break!
Brake shuts off motor automatically, saves energy, improves safety!
Thumb throttle with 3 LEDs indicator lights
Battery charger for charging lead-acid battery
Durable 600D Oxford cloth carrying bag along with a zippered main compartment for battery
We have FRONT wheel kit and REAR wheel kit in store
It's for bicycle only.
Battery Recommendation:
1. Electrokinetic cell battery ( Li, lead-acid, NiMH battery etc.) featured in nominal voltage 36v, nominal capacity not less than 10Ah is compatible with the motor.
2. Please note that the Battery Charger in the package is for lead-acid only and it will damage the battery if you use other types of battery
Added on October 20, 2015
