That's a hard question to answer. the quality of the rim itself.. how it was laced, how heavy you are and the way you ride all make a difference .
Best suggestion i can make is buy the best double walled rim you can find, have it laced by a good wheel builder ( unless you know how to do it yourself ) and pick your tire carefully.
A skinny tire that bottoms out easily will be murder your rim. wide, high pressure ie: 80 + psi, with thick tubes.. double walled rim with Stainless Steel eyelets, etc.. should hold up well..
Was it a single wall rim ? where did it crack ? did you wipe out ?
