Sabvoton controller issues
Bartmarley11
Hi all I have a brand new 100 amp 72v sabvoton with Bluetooth 72v 35 Ah 110amp continuous battery and a cheapo 3000w 72v ebay motor I have tried to swap hall wires and phase wire about some make it scooter running others don't No matter what I do i can't get the motor to run smoothly I think It must be a setting issue can any1 help me work out my offset angle and motor Parameter setting
I don't have a specific answer for your particular problem, but my first recommendation is to look at all the other threads / posts about "sabvoton", as this type of thing has been solved before. A link to those with the name in the title or first post, listed by title. is below, if helpful:
https://endless-sphere.com/forums/search.php?keywords=Sabvoton&terms=all&author=&sc=1&sf=firstpost&sr=topics&sk=t&sd=d&st=0&ch=300&t=0&submit=Search
You can also look up all the posts with it, which may have further info but be harder to sort thru.
