john61ct said:Because the only thing touching that negative that will cause a problem, is the positive side
fechter said:It usually means the negative side of the power supply is grounded or close to ground. There will be HV between the positive and negative terminals regardless, but inside the power supply, one side may be connected to ground. If you had a HV meter, you could measure this.
john61ct said:Yes, "chassis ground" nearly always is what ensures the Common Reference point across multiple circuits.
Some devices end up with potential hot on the outside
and then carry a big warning "intended only for use within enclosed equipment"
or have to use very thorough external insulation to protect the user.
rg12 said:So if the positive arches to the chassis and I'm touching the chassis then I'm getting fried?
john61ct said:rg12 said:So if the positive arches to the chassis and I'm touching the chassis then I'm getting fried?
No, the danger comes when your body (and especially going across your torso not just down one side)
is the "shortest" (lowest resistance) path **between** the positive and negative
> How dangerous 15kv is under such low currents?
> Isn't it like a taser only with a much lower voltage since they both have close to zero current and just make you dance for a moment
Complex question, lots of variables.
Plenty of deaths from getting tased, it is just "less lethal" not non-lethal.
Do some googling soon you will become a relative expert.
