PUMPMANPLEE
10 µW
- Joined
- Jan 13, 2015
- Messages
- 5
ebike gurus
i have the following hardware all connected up
but hub motor will not spin or work
when power is ON & the Thumb throttle is turned.
the THROTTLE SLIDER on the Cycle Analyst
main display can be seen moving up & down
when the Thumb throttle is turned to max & min.
it seems the Cycle Analyst is picking up the
Thumb throttle movement but the hub motor
does not hub motor does not work or rotate at all.
-Cycle Analyst v3.1
-Crystalyte controller 48V/40A
-Thumb throttle
-9C hub motor 500 Watts
has anyone resolved a similar issue ???
-Cycle Analyst v3.1
-Thumb throttle
