mannydantyla
- Joined
- Dec 4, 2020
- Messages
- 126
I have this 100a 20s 72v BMS made by DALY. I bought it on Amazon and it shipped to me with no instructions, no literature, no nothing. Not even any packaging except the cardboard box that Amazon packed it in.
I'm using it for a 20s2p li-ion battery pack that I'm building out of used LG Chem pouch cells from batteryhookup, and the battery pack will power a small motorcycle that I'm converting to electric. So far so good but I have just a few quick questions that I just want cleared up before I start wiring up the battery pack:
Thanks!!
- It has a common wire for both the charger and the discharge. Can I wire the charger and the discharge wires together in parallel? Or do I need to have them seperated by a switch or a diode or something?? The wiring diagram in the Amazon listing shows the charger and discharge wires as seperate plugs that would plug into the battery back but not at the same time. But if I can I would like to have the charger onboard with the battery pack and permanently wired to the bms.
- It has over-current protection (right?). What happens when this kicks in? Will the BMS throttle down the current a little? Or will the bike just suddenly lose all power? And if so, then what happens next? Does it stay off for a few seconds and then turn back on, or do I need to plug it into a charger or something??
Thanks!!
