Kelly controller wont open contactor/turn hub motor
Stancraft67   1 µW
Post by Stancraft67 » Jan 24 2022 6:37am
Hi all I have aktm duke 200 that I have fitted a qs 17x6 12kw hub motor with a kelly kls96601-8080h controller with a 400 amp contactor problem i
Have wired it up as pet kelly wiring diagram for klsh controllers but the contactor won't close it appears that the ground pin 6 is not working as if I connect the contactor directly to battery it will work the capacitors in controller are charging up and are at 109 volts ( the precharge resister is working) when I switch the forward switch and turn throttle the wheel does not move any help would be appreciated
Cheers stan
