ACDC_comeback
10 µW
- Joined
- Feb 27, 2019
- Messages
- 5
I would like to start a thread about the myths of electricity.
And I have one I will talk about it in this post. If you have more Please post them
because this although causes a lot of confusion in the field it also helps our understanding
in the field.
Ever since I logged on to my first electrical forum I have seen the statements that an electric motor is completely different from every other electrical device in that if you apply less voltage it will pull more current from its source. And there is no exception or I have never seen any of the cases. But this is far from the truth.
Now before everyone automatically jumps to the conclusion that I don't understand
inductance and how coils and electromagnets work this is not true. Although I'm not a
genius in the field I do understand that inductors do not follow ohms law to the letter like resistance does.
There are some cases where if you reduce the voltage to some motorized electrical
loads the current draw to that motor will drop with the applied voltage.
If the motor itself creates the load such as a direct drive blade on a fan as you reduce the voltage the current will reduce with it. And I'm sure there are others.
Now on the other hand if you take a motor with a preset load of so much friction such
as a reciprocating pump with a piston in a cylinder which has to push the air through
small orifices and has a constant load on it created from the load itself then as you
decrease the voltage the current will increase.
I know everyone in the electrical field is not in it to understand how everything works and never will have any more knowledge than what is taught to them in electrical school and there are some who just have that drive that just have to know how it works.
To some if there instructor told them that electricity flows faster down hill than it does up hill they would believe it and never question it. And I believe if most have this attitude the electrical field will just stagnate and I hate to see this happening.
in the field.
