Hugh-Jassman
- Joined
- Jun 20, 2015
- Messages
- 407
When I got this mid-drive kit I looked around to find an image by DingusMcgee of a bracket that would hold it rock steady. Then I built my own version. Angle bar and flat bars with bolts holds it very steady. But it is the tube between the two flat plates that makes it wobble proof. So if you have a Cyclone Mini just find a tube that will fit and bolt the two plates together with low headed carriage bolts, to give you room for chain rings.
The shape of the tube does not matter as long as it fits. And it needs to be wide enough to suport a wider area than a one inch round tube would.
I fiannly figured out how to make the two heavy duty chain wheels shiftable:
https://endless-sphere.com/forums/viewtopic.php?f=1&t=97335#p1507238
