technotony007
- Joined
- Nov 23, 2019
- Messages
- 71
I have had a bright idea to build my myself an electric PAN EURO ST1300. ( convert from a petrol engine)
I initial intension is to make the bike from the outside look normal / standard . except for the lack of exhausts.
after doing some research , I found the website : www.goldenmotor.com. which seems to have all the necessary bits , if I based this on a 20kw BLDC motor. This seemed like a one stop shop for me , and all I need then was the batteries. ( and to work out , how many I needed.)
the cost looks to be around $2500 USD , before I source the batteries.
As I am mech engineer by trade , the mechanical side I have covered with little cost.
My thoughts briefly on the design overall are:
Utilise gearbox and clutch off engine, remove cylinder heads and barrels , and somehow graft on a suitable size electric motor. onto the flywheel ,therefore I can still use the gearbox , clutch and drive train.
remove the exhaust and headers, fuel system.
Fit the controller unit and junction boxes to the underside of tank.
Utilise panniers area for batteries and keep the COG low down. ( potential of 20kg per side.)
Convert the harness to power exiting instruments with the new power source. ( step down transformer ,etc. to match previous battery supply.)
keep the wheels & suspension standard.
keep the Tupperware & fairings as standard as possible.
Keep the suspension as standard ( non ABS.)
redesign the new EV electric motor mounts and couplys accordingly to fit where the alternator used to be.
As I am using the engines mechanics to transmit te power to the rear wheel. I believe I would require the same or similar standard st1300 power to run the engine efficiently.
the standard St1300 engine produces:
Maximum power - Output - Horsepower 118.00 HP (86.1 kW) @ 8000 RPM
Maximum torque 117.00 Nm (11.9 kgf-m or 86.3 ft.lbs) @ 6500 RPM
there is 3 choices of EV motors I have thought about. the first is :
The second is BMW X6 HVH250 hybrid motor (ebay) - 63kw or @ 280 volts dc , max rpm 10600 ( trying to research if feasible, ie what controller , would need , and how many battery's to cover the voltage for 300 miles.)
the third is EV motor 60 kw ( ebay ) , 137nm of torque at 14000 rpm. ( 3 phase , so power would have to huge , so probably this most probably impracticable.) see link below,
https://www.ebay.co.uk/itm/EV-MOTOR-60KW-14000RPM-137NM-ELECTRIC-PROJECT-EMRAX-REPLACEMENT/293332459835?ssPageName=STRK:MEBIDX:IT&_trksid=p2060353.m1438.l2649
My electrical knowledge is poor , as mechanics is my thing. some any advice or whether these would be suitable would be greatly appreciated.
my next challenge was the power ( i.e. batteries.) my thoughts from cost , and what's readily available is to use the follow car batteries from a Nissan leaf :
Nissan Leaf Gen2 Module | Lithium | Powerwall | EV | 7.6V | 56.3Ah | 427Wh | eBay
has anyone done this type of thing before ???? ,matching a EV electric motor , grafted onto a deconstructed engine.
any thoughts or idea's would be greatly received.....
regards
tony
regards
tony
