E-Grom Clone 72v battery upgrade recommendations -Update bought a Leaf Pack
johnnyddn   1 mW
Post by johnnyddn » Mar 25 2020 10:29am
I got a Jiangsu Xinri E-Grom clone with SLA batteries that are tired and need to be upgraded. It currently has 72v 32ah of lead acid in it. I used to do 46mph according to the gps, but only does 41-41mph now. I've been looking at getting some 70% capacity Nissan Leaf Gen 2 cells tested at 41-43ah from Greentec Auto. I think I can get 10 of them for around $600. I was also looking at possibly doing CALB Lifepo4 40ah cells but that would be more than double the price and maybe a little bit tougher to fit them all in the chassis. I'm looking for recommendations on how you guys would run your setups or what batteries you would choose. I also thought about running Chevy Volt cells but I haven't seen them as cheap or available as the Leaf cells. I'm also not sure how to connect individual Volt cells if I need to split up the pack to make it 72 volts.
Here's the measurements of the battery tray. I believe I can get 6 Leaf cells laying down and 2+2 on each side of the main chassis bar for a total of 10. I think I could possibly get 2 more on top of the chassis bar for 12 cells if I cut the plastic fake gas tank or maybe fab up one outta sheet metal. If I could find another plastic gas tank I would cut it up, but replacement parts are hard to find in the states.
If I go back 12inches from the front of the battery box, I can get about 8.5 inches in height which I believe should clear 6 Nissan Leaf cells stacked up.
Width of battery box from bottom
Then I was gonna put 2 on each side of the chassis bar like how the current SLA's sit.
Should kinda look like this.
Yermommy   10 W
Re: E-Grom Clone 72v battery upgrade recommendations
Post by Yermommy » Mar 29 2020 2:17pm
I'm curious to see this build but none of your pictures have loaded. You might want to double-check how they were uploaded.
johnnyddn   1 mW
Post by johnnyddn » Mar 29 2020 10:14pm
I believe I fixed the photo issue. Thanks for the heads up.
Yermommy   10 W
Post by Yermommy » Mar 29 2020 11:31pm
Most of the images are loaded now. If you want to put all 10 batteries in, you may want to consider widening the battery box. If you choose to only use 5 of those leaf batteries, this is an excellent tutorial about how to convert them from 2s2p to 4s1p [youtube]kAznO_p_rEY[/youtube]
johnnyddn   1 mW
Post by johnnyddn » Mar 30 2020 7:02pm
Thanks for the link on the tutorial. That will be useful in the future if I have a project that can't fit as many Leaf cells. I would like to get 10 cells for now to keep the pack at least 72v 40ah. I don't wanna go much lower in the amp hours because the range would be terrible.
biothundernxt   10 mW
Post by biothundernxt » Jun 14 2020 5:54pm
I just ordered one of these (the grom clone) and I already have a pile of leaf batteries.
I am planning to do this same upgrade when it gets here to get better range than stock.
Did you ever get anywhere with this upgrade?
johnnyddn   1 mW
Post by johnnyddn » Jun 21 2020 9:13pm
Nah, unfortunately I haven't ordered batteries yet. The whole covid lock down thing happened here in Vegas so I didn't make any extra purchases.
John in CR   100 GW
Post by John in CR » Jun 22 2020 2:14pm
johnnyddn wrote:
Jun 21 2020 9:13pm
Not UNfortunately, it's fortunate you didn't order some Leaf modules with 70% capacity. Those would be very worn out batteries likely to sag a lot. Years ago I bought some batteries from an outfit in Vegas. I forget the company name, but they shouldn't be too hard for you to find. What you want is batteries from a low mileage wrecked car, not worn out batteries.
johnnyddn   1 mW
Post by johnnyddn » Jul 17 2020 1:22pm
John in CR wrote:
Jun 22 2020 2:14pm
johnnyddn wrote:
Jun 21 2020 9:13pm
I just purchased an entire battery pack from a wrecked 2016 Nissan Leaf with 18k miles. I was billed ~$1300 shipped, which seems like a great deal to me. The yard says the car has only been there 3 days so I didn't see pictures. I verified with the person that this is the entire battery pack twice, and they said yes and even put it on my invoice. I'll see if this actually goes through and if the battery pack still has decent capacity...
TorgueRPM   100 W
Re: E-Grom Clone 72v battery upgrade recommendations -Update bought a Leaf Pack
Post by TorgueRPM » Jul 17 2020 1:55pm
If those cells work out for you I may be interested in buying some of the extras.
johnnyddn   1 mW
Post by johnnyddn » Jul 17 2020 2:14pm
TorgueRPM wrote:
Jul 17 2020 1:55pm
Yeah, you in Wisconsin? I'm in Vegas, I'm not sure how much shipping would be up there.
Since I was able to get a full pack (hopefully, not in my hands yet), I think I'm gonna go with 11 (I'm reading the modules are 7.5v each) modules for around ~82.5 volts if I can get them stuffed in the bike. 12 modules later but I think I'm going to have to upgrade the controller, motor., DC voltage regulator. I'm gonna go with the Cycle Satiator Charger - High Voltage model, up to 103v at 5A. Do you guys have any other recommendations? I've seen some guys using Mean Well chargers in series also.
https://www.ebikes.ca/product-info/cycle-satiator.html
TorgueRPM   100 W
Post by TorgueRPM » Jul 17 2020 2:28pm
https://bmsbattery.com/ebike-charger-ev ... command-no
This is what I use on my Boom Egrom. I'm currently using SCiB Lithium titanate but they kinda suck on energy density, only ~2x that of lead acid. But the charger is great so far, and has an led screen that tells you voltage, amperage, and how long it's been charging. I use the same brand for my longboard. If you have access to 220v, you should be able to charge at 13A with that model.
johnnyddn   1 mW
Post by johnnyddn » Jul 17 2020 2:47pm
TorgueRPM wrote:
Jul 17 2020 2:28pm
Is the end user able to adjust the voltage of this charger or is it a one time deal how I order it? You have posts or pics on your bike? What voltage are you running at? Please give details of your setup, hah.
Also Torgue for Borderlands was awesome, he cracked me up.
TorgueRPM   100 W
Post by TorgueRPM » Jul 18 2020 5:42pm
BmsBattery chargers are know for being adjustable with internal potentiometers I believe, although I haven't opened my charger to verify that.
I don't have any good pictures of my bike right now but I can take some on Monday.
I'm running a nominal 78v, charging to 85 because my ASI BAC4000 can't handle more than that. The battery would charge to 97v full. I measured and actually only got about 1kWh out, which means I'm only getting ~2/3 of the energy the battery can offer in a charge :/.
I have it set to 12kW right now (150A battery and 250A phase) and it pulls pretty hard. I use about 2kW continuous on level ground with no wind at 35mph. Getting 39 wh/mi according to my cycle analyst.
TorgueRPM   100 W
Post by TorgueRPM » Jul 20 2020 1:24pm
I just created a thread for my build here:
viewtopic.php?f=12&t=107387
TorgueRPM   100 W
Post by TorgueRPM » Jul 22 2020 10:24am
johnnyddn wrote:
Jul 17 2020 2:47pm
TorgueRPM wrote:
Jul 17 2020 2:28pm
Opened up my charger and could not find a pot for adjustment :/
johnnyddn   1 mW
Post by johnnyddn » Jul 24 2020 9:17pm
I knew it was too good to be true. The scrap yard cancelled my order and refunded my credit card. Maybe someone there bought it before they shipped to me because I don't see it up for sale at a higher price or anything. The excuse was the pack turned up missing. Anyways...
I saw that BigBattery is having a sale on complete Gen 2 70% capacity packs for $1350 after coupon code POWERWALLS. I was thinking about picking up one of those. Anyone in the Cali/Vegas area wanna split a pack? I could buy half, but really only need 12 modules for my project.
https://bigbattery.com/product/nissan-l ... n2TRhWlseo
