boars
Hey guys, had a bit of a dig around and have been unable to find much of anything where people have replaced their standard ICE petrol cap assembly with a 240/120V type setup.
Is there any sort of kit out there that makes this an easy proposition?
Most of the outside/water resistant AC plugs I'm aware of are designed to be mounted on vertical walls and RVs etc.
I've not been able to find any info on something that'd suit being mounted to the top of a tank.
Someone must have done it, anyone got any info/links?
Closest thing I could find was something like this:
https://no.co/gcp1
I just want to plug in a standard 240v Australian plug but would consider other options if it's just way more practical to use a different kind of plug and then carry an adaptor.
It's probably easier (especially dealing with water resistance) to simply plug the hole and have a cable tucked up into the fairings but I really like the idea of just plugging into the top of the tank for some reason.
Cheers.
https://no.co/gcp1
Cheers.
