HughJass
Back in April I got an onyx RCR second hand, wanting to get a bit of hands on experience with some EV mods/set up. I started with some minor changes; wired up the turn signals, cooling for the controller and motor, upgraded battery, but it was always limited to 50mph max. I figure since the QS 205 should be good for more than a 3kw controller, and the BMS on the new battery is rated for 150A, I could swap in a better controller to hopefully boost the performance a bit more. I'd be happy to at least get the 60mph mark, and evaluate from there if I can tweak it any further.
I bought a sabvoton 5kW 150A but I'm not going to try anything out until I'm a bit more secure with how to safely install it.
https://www.aliexpress.com/item/4001248496230.html?spm=a2g0s.9042311.0.0.63b04c4ddt2eKE
I tried digging around for examples of swapping controllers but haven't found anything which really lays it all out. Is there any kind of walkthrough or instructional on doing controller installation?
