redneckbluecollar
- Joined
- May 14, 2021
- Messages
- 1
Hey guys first post here. Gio Havoc 72 volt with a 2000 watt control box. Power cuts out after 2-3 seconds on throttle. If i shut the key off, turn back on then same thing, goes then cuts out. Batteries are new and charged up. the bike came from the manufacturer not working. I put in a new controller which didnt change anything no go at all. Got a new motor from manufacturer under (warranty) test drove good, it worked for a day then it quit. I swapped the old control box back same thing. Installed a 3000 watt controller we have but now goes for 2-3 seconds then cuts out. Anyone heard of such an issue. Im going to try another motor but cant keep doing this over and over. Also after it cuts out i do have a good throttle signal to the controller and can hear a slight tink tink noise at the motor as i try the throttle as soon as it cuts out but that noise does not happen once the wheel (motor) stops moving.
