Greetings,
I have a Super Soco TSX that I've been using for about 5 months and it has 3,300km on the odometer, recently I purchased new larger Tires (from 90/80/17 to 110/70/17 front, 110/80/17 to 130/70/17 rear) and a Second Battery (60v30ah ) with the official Super Soco Paraleller (which in reality it just switches the batterys every 15 seconds). After said upgrades I've noticed a significant reduction in acceleration from a stand still and slightly lower Max Speed (63kmph compared to 67kmph pre upgrades), while I understand these things were supposed to weight down the bike and increase rotational mass for the tires, I wasn't expecting it to be so severe. So I'm now looking to upgrade into a QS Motor 273 4kw Hub and a VOTOL em 100 or 150 for a quick and easy upgrade.
Questions are:
Can I parallel both batteries to the controler? (they are identical in V and AH, also theres a video of someone just plugging the - and + of the second battery and just using the BMS information from the first battery to communicate with the Controller. (video link https://www.youtube.com/watch?v=V16n56fAApw) (Video is in italian, i can't understand most of what he says.)
Will this (https://www.aliexpress.com/item/33053979766.html?spm=a2g0o.productlist.0.0.16ca7743Bx73fX&algo_pvid=c00c6a01-a773-49fe-9e5a-acd2afc1a4df&algo_exp_id=c00c6a01-a773-49fe-9e5a-acd2afc1a4df-13) 4KW motor be enough for me (6,1f 110kg with gear + mounted box with tools)to reach top speeds of 90kmph and have enough pull to get off the line fast enough?
Is the VOTOL em 100 or 150 enough, configurable?, I'm looking for options into regen breaking and reverse.
Both batteries are still under warranty (2years) so I don't feel like dissasembling them. I can ask QS motor to configure the Motor for 60v, what other factors should I tell them to set up?.
Thanks for taking the time, I looked at the TCMAX but its pretty much US$7,000.00 which is twice as much what I paid initially for the TSX, and i already have 2 Batteries.
Images of the SS Paraleller for those interested.
https://imgur.com/a/zE136l0
Questions are:
