Suggestions wanted for p42a battery packs
Pete's moto
Mtl
I'm converting an RMZ250 and like many here I want to use the QS138 70H with gear reduction and paired with an EM260 controller.
When trying to source p42a batteries to build a 20s14p pack (looking for 350A burst)i came across these 2 battery packs lightly used by university students for a project.
I purchased the packs and they seem well built
16s10p x2 and if connected in series would be a 32s10p pack. If installed as is, no midrive motor will fit the rmz frame would have to go with hub motor.
So I don't know, should I take at apart and build the initial 20s14p or keep as is and get hub motor run it at 100-120v?
Any suggestions would be apreciated
Nothing wrong with a hub motor if you have a matching controller. More space, no chain.
If you want to ride sporty/twisties, then probably not - for commuting/leisure it's fine.
