KTM Freeride E-XC Akku repair
steve2000   10 µW
10 µW
Post by steve2000 » Jan 10 2022 5:53am
Hy, I know a lot of people who want to see this::
See Attachments ....
KTM Freeride E-XC.jpg (137.89 KiB) Viewed 839 times
KTM Freeride E-XC_Akku_Schnitt.jpg (117.16 KiB) Viewed 839 times
KTM Freeride E-XC_Akku_Zelle_raus.jpg (478.39 KiB) Viewed 839 times
KTM Freeride E-XC_Akku_zerlegt.jpg (776.07 KiB) Viewed 839 times
KTM Freeride E-XC_links.jpg (49.04 KiB) Viewed 839 times
KTM Freeride E-XC_Motor_links.jpg (86.7 KiB) Viewed 839 times
KTM Freeride E-XC_Motor_rechts.jpg (85.27 KiB) Viewed 839 times
KTM Freeride E-XC_Rechts.jpg (112.31 KiB) Viewed 839 times
rg Steve
Professional on BIONX systems
jhoexp   100 mW
Re: KTM Freeride E-XC Akku repair
Post by jhoexp » Jan 10 2022 7:09am
Thanks for all the pictures, first time I can see inside that battery brick!
It's 3 layers, right? 120 cells per layer if I counted right, so 360 cells total.
And they wasted all that space using 20R cells. Unbelievable.
Are all the metal rods (except the threaded ones, that I imagine are to close the structure) for cooling? They just exchange heat between the cells and the large plates?
steve2000   10 µW
10 µW
Post by steve2000 » Jan 10 2022 7:50am
Samsung SDI INR18650-30Q 18650 3000mAh 2670mAh 20.0A
would be a good choice for an update.
1/3 more Wh ....
rider119   10 mW
Post by rider119 » Jan 12 2022 12:51pm
Nice, cool too see inside that pack! Thanks for posting and will be interesting to see how the repair goes. Good luck!!
steve2000   10 µW
10 µW
Post by steve2000 » Jan 17 2022 7:32am
Repair was successful.
The error was gone.
Replaced one cell and all voltages are back to normal.
Electronics took a while to relearn.
Despite being fully charged, it had to be charged for a long time in order to be fully displayed again.
And don't be afraid of the volts. 100V You don't feel it at all. 200V makes a little shock. To be on the safe side, I didn't try 300V again :lol:
jhoexp   100 mW
Post by jhoexp » Jan 17 2022 4:29pm
steve2000 wrote:
Jan 17 2022 7:32am
The error was gone.
There was just one bad cell and the pack was unusable because of the error?
liveforphysics   100 GW
Post by liveforphysics » Jan 17 2022 9:32pm
Thank you so much for your hard work to share these pics with us all! :bolt: I wanted to know, and you saved me the time and money to find out!
steve2000   10 µW
10 µW
Post by steve2000 » Feb 02 2022 4:36am
jhoexp wrote:
Jan 17 2022 4:29pm
steve2000 wrote:
Jan 17 2022 7:32am
The error was gone.
We were lucky. One cell pulled the other 6 down in parallel. As a result, too little voltage in one bank on the balancer and battery was no longer usable
steve2000   10 µW
10 µW
Post by steve2000 » Feb 02 2022 4:37am
liveforphysics wrote:
Jan 17 2022 9:32pm
You're welcome
SaltyBill   1 µW
Post by SaltyBill » Feb 24 2022 1:17pm
Hi, I am buying a used KTM exc freeride soon, i was wondering . If i was to replace the 2000mah lipos with 3500mah lipos will i need to do anything else. Or just soldering in the new batteries is enough. Will the software and bms recognise the larger battery and ill have increased range?
Is it that simple?
Does anybody know someone who has upgraded these battery packs.
I read the new batteries from the 2021 model come with 3000mah lipos..
thankyou
