Kuberg Cross Controller Help
trm122
Riding in the rain got to the OEM Kuberg controller. I replaced it with one of these https://www.amazon.com/L-faster-Sco...1652747144&sprefix=,aps,102&sr=8-7&th=1&psc=1, and while it works, it doesn't have the same current which makes the bike not have as much hit (top speed is the same). I don't really want to spend $500+ for a replacement Kuberg controller.
I even considered the OSET 16.0 controller which is 40AMP, but not sure about all the other wiring. Ideas? If it matters the bike has a 20AH lithium pack, 50AMP BMS and 50AMP fuse.
What was the original controller current limit? Using one with the same should give you about the same performance.
Some controllers have a soft throttle response, isntead of instant start; even with the same current/power it has a slower reaction; less "oomph". Most ads don't specify which they have, though. :(
