GBarker123
- Joined
- Mar 23, 2019
- Messages
- 2
Hi everyone - I'm the original owner of a 2008 (or 2007?) Zapino scooter, and I am having what I think are controller problems. With new, charged batteries, upon even mild acceleration the controller/motor appears to jump into the "protective" mode - that is, the maximum power draw is about half of normal, and of course so is the speed. It has always done this when the battery voltage gets low, as a protection against too much current draw I suppose. But now it does it even with new batteries fresh off the charger. I'm monitoring the voltage of each battery and all looks good.
I tore things apart and found two 3-phase controllers connected to the motor. The motor is reported to be a 3 kW, 6-phase motor. Each controller feeds 3 phases. I'm willing to buy a pair of new controllers such as ( https://electricscooterparts.com/hookup/SPD-602000BLDC.pdf ), but the problem is trying to figure out which Hall-effect sensor wire corresponds to which power wire on the motor.
The thin wires going from the controller to the motor are labeled "HA", "HB", and "HC", which I'm guessing mean the Hall-effect sensors for phases A, B, and C. The thin wires going into the motor are two each of the colors (at the motor) yellow, blue, and brown. The 6 power wires to the motor are yellow, blue, green, red, white, and black. So there are 6 Hall-effect wires (2 yellow, 2 blue, and 2 brown) and 6 uniquely-colored power wires. I was hoping that I would find 6 uniquely-colored Hall-effect wires which corresponded to the 6 uniquely-colored power wires, but no such luck.
My question is this: does anyone know a way of determining which Hall-effect sensor wire corresponds to which power wire? I don't see how I'm going to be able to replace the controllers without knowing this.
