Returnformer said:
my bike is also a 48v battery, 52 cell lithium ion, i think, otherwise, yeah, itd obviously be different cutoffs.
If it shuts off at 36v, then something is wrong with the system. A 48v lithium battery uses 13 cells in series to get the 48v (nominal), which is about 54v fully charged (4.2v per cell), and around 42v empty (about 3.2v per cell). (yours would be "4p" or four cells in parallel in each of the 13 groups, to get 52 cells).
Technically they may be able to discharge down to 2.8v per cell to totally dead, which would be about 36v but that's really not good for them, and repeatedly doing that will shorten their lifespan. It's pretty much just an emergency cutoff voltage, below which permanent damage to the cell can result (some of which can cause a fire, if not during discharge then during the subsequent recharge).
So it sounds like you have a controller that does not have it's own LVC, or it is set wrong, perhaps for a 36v battery instead of a 48v, so it is allowing discharge below about 42v, which it shouldn't.
I'd recommend putting a wattmeter on there, so you can stop discharging manually once it reaches 42v or so. Then you can look at how many Ah / Wh that is, and then keep track of your Ah / Wh usage. That will let you know about how much range you have left, as the battery ages it'll get less and less.
A simple voltmeter could also be used, but it will not give you the other useful information.
so it doesnt sound like anythings wrong with the bike itself, then? just needs a new battery, not that itll get a ton more range with one?
Probably nothing wrong with it based on what's been posted so far, other than an old SLA battery. More range will depend on the size of battery (watt-hours) vs the power demands of the scooter.
You may be able to use your ebike's battery to test the scooter with, if the bike's battery can handle the power output the scooter requires. (you can check the A rating of the controller on the scooter, if it's marked, with the A rating of the controller on teh bike, if it's marked. If the ratings are the same, or the bike's is higher than the scooter, then it should be safe to test. If the ratings on the scooter are higher than teh bike, then the scooter may need more power than the bike battery can supply safely (assuming the bike battery is rated to match the bike's controller).
