This bike is freaking fast! I just got a new Talaria Sting R and her bike is keeping up with me at 44mph! (her battery is 20s4p 21700 20ah)
I just put new front brakes on the bike since she wore out here first set of vintage Julie hydraulics, she wore out the rear brakes 6 months ago and i upgraded those to actual hydraulic dirt bike calipers off a 125cc
and now she needs new headset bearings. Since we are using a Cane creek 40 headset for a dirt bike frame it is a tad bit loose, i shim it with some sheet metal but it seems to wear the bearings quicker than normal. i added a wrap of aluminum tape to get it even snugger but now bearings have failed
The throat of the headset cups were a tad smaller in diameter than I would have preferred, hopefully the headset holds up with the shims in place
also the rear sprocket came of yesterday when we were riding hard on the train tracks, three of the six bolts snapped off leaving us to limp home at 5mph with 2 bolts left holding it on wobbling back to the house(one bolt broke months ago) we made it home but the second she pulled into the yard the chain fell off!
So after the rain stopped i took the entire rear wheel off Dremel cut the snapped allen bolts out of the 6 bolt ISO of the hub and reversed the wheel(these wheels have 6bolt ISO on both sides) I put the mangled stripped pattern on the disc brake side since it doesnt see as much torque or action compared to this huge stand off sprocket. Then i started re-mounting everything a tad differently than i did before
prior i was using 6x 1/4" rod couplers to stand the sprocket off the hub to get closer to the motor sprockets chain line, but that was putting too much stress on the 6-bolt ISO. So i cut the stand off distance in half so i can use much shorter bolts, and then i had to take the front sprocket off the LR small block and turn it inside out so the teeth are closer to the motor to improve the chain line and make the motor drive spin freely. Doing this made the chain almost fall between the frame and the swingarm since its now much closer in, so to fix this i tek screwed a chain slide that overhangs the swingarm on the inside so the chain cannot fall in between.
This is a picture of the old bad mounting
