Recently I've acquired 10.4Ah 48V LG M26 pack from Unit Pack Power together with 2A charger.
The battery was removed from the bike, the switch is in off position and it's connected to the charger.
When the charging was over, indicated by the led, switching from red to green, I've disconnected it, turned on the battery and measured the voltage on the battery connector where the motor is connecting. Voltage is 53.5V. This means cells are charged to 4.11V, not 4.20V.
If I connect charger again but switch the battery to on, it will start charging. If the battery is in off position charger is reporting battery is full.
Any idea what's happening here?
