I built a few large 18650 Lithium battery packs recently, one using smart BMS and the rest using no intelligence BMS. for one battery packs using no intelligence BMS, one parallel group of cells discharge quicker than the other parallel groups of cells (when there is no load applied). for example, when fully charged each parallel groups of cells to 4.19v, one day later, the voltage of the quicker discharged parallel group of cells decreased to 4.13v (decreased about 60mv in one day), while the voltage of the other parallel groups of cells decreased to 4.18v (decreased about 10mv in one day).
when assembling, there wasn't short circuit occurred for this quicker discharge parallel group of cells, while there was loose soldered wires (balance connector cable) discovered for this parallel group of cells when the whole battery pack assembly was finished and was being charged, then I re-soldered the wire for this parallel group of cells, then found out that this parallel group of cells discharge quicker (when no load applied) than the other parallel groups of cells.
don't exactly know why this parallel group of cells discharge so quick. could this parallel group of cells make impact to the whole battery pack when used in ebike application? is there a way to repair it?
all the other battery packs assembled are in good condition.
