- Joined
- Jun 30, 2019
- Messages
- 12
Evening all.
Ive spent the last couple of weeks researching for my problem, and whilst I have learnt a lot Ive also managed to confuse matters at the same time. I'm hoping someone maybe able to help me clarify a couple of things.
The pack I wish to build is purely to extend the range on my Diver propulsion vehicle(DPV) speed is not an issue. I currently have a 25V 512 Whr cell.
with the room I have available I think 18650 cells are the way forward and after much reading I think panasonic 18650B 3350mAhr are the right cell.
Now then as has been advised on a seperate thread go big. However this project isn't quite that simple. As I add cells not only do I add mass but I remove air(buoyancy) and my DPV becomes negative, ie sinks. this is extremely undesirable. Whilst it is possible to add buoyancy this requires a structural change and it complicates the matter further.
This is basically the reason for going self build rather than buying a ready made unit. I want to start with 7s13P, which should weigh in about 42/4300g after its put together, but be slightly smaller than the existing unit, and hence be more buoyant. If this works ok I can then add, or if needs be remove a parallel set.
The question Im asking is therefore, would you agree with my choice of cell?
I'll purchase a spot weld module if need be, so therefore weld vs solder?
Would one of you experts be willing to give me a few pointers in layout/design once I have all the bits and pieces? For this to work I think its going to be 2 layers of cells around 150mm dia. with a bms in between. Im thinking I can therefore encase the whole thing in a 150mm pipe and make waterproof, in the event of a catastrophic leak I wont kill the cells.
Many thanks
Simon
Many thanks
Simon
