billyjones454
- Joined
- Feb 16, 2011
- Messages
- 44
Hi all,
I'm trying to resurrect an ebike project I had running years ago, and have some questions about getting a BMS going. Please forgive me for asking a dumb question.
TL;DR: I'm building a 20s2p pack out of turnigy 5s. Do I use 8 5s BMS boards, or two 20s BMS boards?
My aim is to basically make the balancing/charging/monitoring portion of the ebike completely self regulating. I have heard arguments in the past that you can bulk charge, and that the cells won't drift too much. But I don't want to mess with any of that. I just want to be able to plug in 1 plug, and charge it easy peasy. If a cell goes out, I'll just replace the pack.
So, my current pack is made up of turnigy 5s packs in a 20s2p setup using 8 packs total.
My question is, I don't think I can put a 5s bms on each pack right? I need to put a 20s BMS board on each paralleled pack (so two 20s BMS boards), does this sound correct? Also can I use a BMS that is advertised as a Li-ion bms?
Also does anyone have any recommendations for appropriate boards on aliexpress or ebay?
Thank you!
Thank you!
