This question has been of interest to me for some time, from another thread.
And keeping cells from getting too hot is in general A Good Thing.
I am skeptical that active cooling in itself would lower the longevity hit of fast charging.
Better to charge at lower C-rates whenever possible, only occasionally do we really "need" fast charging.
Also note if you're going to discharge at high C-rated, draw down high DoD anyway, as is common for EV usage, then you're not getting great longevity anyway, the added "abuse" of fast charging may well come out in the wash.
My understanding is that yes, heat is **correlated** with the chemical over-activity that causes high charge C-rates to reduce longevity.spinningmagnets said:I am no electronics expert, but I collect information from many sources that seem to be competent. EV cars have a large battery pack, and after that large pack has been depleted, many potential customers express some concern over the amount of time needed to charge up the pack.
To address these concerns, many products make sure to emphasize that "in just 30 minutes" that perhaps 100 miles' worth of range can be added by a smart charger.
That caught my eye. Apparently, when a pack is empty (*3.0V per cell) it can absorb a higher rate of charge than when it nears a full state of charge state.
So then, it appears to me that the fastest possible charging would incorporate a sliding amount of amps, that is tied to the heat of the pack. And...if that is true, then pack cooling can increase the rate of the sliding charge.
