OP - you are thinking about this in the wrong way. You are not measuring four, 14S groups, you are measuring fourteen, 4P groups. Parallel adds amps, series adds volts.
The numbers will be additive, ie 4.2, 8.4, 12.6, etc. Important to write these down as there will be some minor fluctuation, and maybe a major one. That big one is the one you are looking for.
4.2, 8.3 (this measures a 4.1, second group), 12.5, then 16.2, instead of the expected 16.7. The fourth group shows a charge of only 3.7. That is a problem. Check all four cells and replace the bad one, or more. You may be able to obtain a matching cell from your vendor under warranty.
Or not.
You will likely see a much larger discrepancy than that listed, or perhaps more than one. Check ALL strings, post ALL numbers, as originally measured. Doing it twice and verifying all numbers, also a new battery in the voltmeter, is not a bad idea. While I have only shown one digit after the decimal, you should have two.
