garolittle
Hello. I am using a 14S/20P pack of LG HG2 cells (“18650 lithium ion”) for my prototype electric go kart.
What is a safe charging rate for a 20P configuration? I typically charge at 15-20 amps (CCCV)
What is a normal “Minimum Voltage per cell”. I have an Orion JR. BMS that is set for 2.9V minimum but I am wondering if that is too conservative. The spec sheet for the LG HG2 shows 2.5V as the minimum but I do not want to go that low for a variety of reasons.
What is typical “safe difference” in cell voltages after discharge? I pull approximately 100 Amps (continuous) and 350 Amps (maximum “bursts”) on my electric go kart and usually have about .03V to .05V difference between the highest and lowest cells. Is this a good range?
Thanks for any responses or suggestions.
Gary
Gary
