ThomasEekels
- Joined
- Aug 18, 2019
- Messages
- 27
Hi to you all.
I am into design (and later and build) my own hexacopter, that will be powered by a 3s Li-Ion pack.
I want to hide the batteries into the frame components, which could be done in the rotor arms.
Each arm can hold at least one 3s pack, (may be even 2). Let' s start with one, for the discussion
Of course I want to balance the cells while charging.
When I google for a 3s charger, I find balanced chargers that have 2 connectors, one for the charge wires and one for balance wires, I guess. Am I correct that the designated 3s pack will have balance wires in it, but no BMS ? As the BMS is in the charger ? (On my e-bike, the BMS is in the pack itself, not in the charger)
This brings me to question 1: Is balancing a ' charge' thing, or also a ' de-charge' thing ?
If not, I will build 6 packs and charge them, balanced, individually. (May be with 6 parallel balanced 3s chargers in a diy power station)
Than, I will wire/connect all charged packs in parallel to a power hub I want to build in the copter.
This will render the set virtually as a 3s6p.
From the power hub I will power the hexacopter.
Is this a viable concept ? Or do I miss some essential Li-Ion technology demand ?
Please surprise me
Rgrds Thomas
Please surprise me
Rgrds Thomas
