fredfire said:
I have three small 4000mah 4S lipo batteries(turnigy graphene) that I charge separately , and put them in series(3X xt60 to one xt90) to use with my bbshd.
Does a BMS exists for charging only those batteries? Something I could plug all balance wires into and plug the series discharge lead to charge.
keep in mind you cannot parallel the balance leads, so you need three separate units, or a wiring harness to connect the three seriesed packs to that connects the balance leads in series as well.
if you parallel the balance leads, you short the batteries out, and either destroy the balance leads or possibly set the packs on fire.
but the shorting out would still destroy them.
you could use the various rc battery meters, one per pack, like battery medic, celllog, or other similar things, if you need to see all the voltages at the same time. or something like the 12s thunderpower flattire proposed above, presumably using a harness made to connect all the leads in series. (*not* parallel! -- very important!)
however...nothing other than a complete bms system will actually protect your packs against overcharge when bulk charging them in series, if that's your goal, because it's the only thing that can shut off the charging input when any cell becomes full.
there are two basic kinds of bms, balancing and non balancing; you probably want the balancing kind.
each of those two kinds are further subdivided. some have a single charge/discharge port, and some have separate charge ports from the discharge port. if you use the latter type, you *must* charge thru the charge port *only*, or the bms cannot do it's job to protect the cells from overcharge.
the meters can only monitor and display voltages, sometimes balance cells very slowly.
rc chargers (which is probably what you use now) can act like a bms and a cell-level meter display and a balancer, but you either need three of them (one for each seriesed pack) to charge the packs while seriesed, or you have to do what you already do.
