Recommendations for 30s lipo charger
larsb
Gothenburg, Sweden
Hi, building 30s 30Ah battery, need a charger. Preferably with option to set voltage 120-126V and do currents above 2.5A (so no high power needed)
What do you recommend? Been looking at meanwell led drivers 3x42V in series but total cost for the ones i looked at will be 200 usd or so. Isn’t there a better option? It will be for home charging / indoors so doesn’t have to have IP classification.
You think a couple hundred is expensive??
Not for a high voltage like that, and certainly not for good reliability plus user adjustable voltage.
I mean yes, you can cobble together quality secondhand gear, ex-telecom / server room PSUs plus DCDC converters in series / parallel if you have the skillz.
But that is a lethal voltage there!!!
My approach would be break the pack down into modules with serial connections, reliable robust and easy to make/break.
6-8S even 10S units give lots and lots of choices in excellent balancing chargers, not too pricey even at higher amps, some can do multiple sub-packs at once.
10S getting up there more rare thus expensive, 12S forget it.
Of course if you come across a good used high-voltage charger from the EV world ($200 for an Elcon would be a steal) then normal cycling could keep your pack assembled at full voltage
and use the hobby charger for maintenance, SoH% cap testing, resistance benchmarking balancing etc.
Note that to be safe
or even to be called a "charger"
the unit should be self-terminating.
Rectifier/PSUs and DCDC converters do not do this, so you'd want to rig an HVC cutoff.
BMS is there as a safety fallback failsafe backup in case for when your primary regulation circuits fail.
Some expensive ones can control an Elcon etc with CAN commands, but you aren't paying for that level of quality if you think $200 is expensive for a good charger.
Safety first, worth spending more to not burn the house down.
I don’t see the issue with cc+cv LED drivers without charge cutoff?
When battery is at the set voltage on the driver no more current will flow. Might be some losses in the driver but the meanwells seem to be able to take it.
Might need some diodes for reverse voltage protection.. need to check this.
Battery will be protected by bms off course, at a slightly higher voltage than the driver.
It is really not a good idea for longevity's sake to keep charging past amps trailing past say 0.05C, maybe 0.02C at most, even at a reduced CV setpoint.
But yes for fire safety, so long as
your BMS is trustworthy, and
you're not just relying on one level of protection, you're probably OK.
I have a big pile of HLG-240H-54As, 50-57v about 4A each
going for $40 each plus shipping if you're interested.
I hear they are isolated, so can be serial-connected with each other, and the other voltage units in that line just fine.
The lowest current unit would apparently limit the rest, so best if the others used were also around 4A.
If you're OK with a finish capacity slightly below "vendor rating 100%"
which is better for longevity anyway
the I **believe** there is no harm in putting a 30S pack onto a charger rig putting out say 150V
So long as your adjustable HVC terminates the AC input to the PSUs when the charge-circuit / battery voltage reaches your desired setpoint.
CC-only, no holding Absorb at all.
If the current rate is over 1C, you might finish at say 5-7% below "vendor rating 100%". At slower rates, probably over 98%.
But you definitely want redundant protection there, the HVC failing could render the bank scrap and the building a smouldering pile of rubble.
Crossthreading: https://www.endless-sphere.com/forums/viewtopic.php?t=92316
As always i’m not first :wink:
I’m looking at having three ELG-150-42AB in series, would fulfill all requirements i had at 35$ each so basically a configurable charging system at 105$, that’s not bad.
Yes ELG series not quite as good as HLG , but so long as you get adjustable versions should be fine
