14S battery with modular diagnostics
Gizmosis350k
Hello guys i wish to make a new triangle pack based on this design
https://endless-sphere.com/forums/viewtopic.php?t=96884
that will have
2x JST-XH for 7s each
these JST will be connect to RC voltage meter AND 7s active balancer
AND typical resistive BMS over the same cables.
Is this feasible or will I fry something?
Technically XH is rated 3A
but can go a bit higher no worries.
Personally I'd run at least two in parallel.
Two active balancers? Or two sets of JST for balancing/monitoring voltage?
I hear the ghost drain on the RC Voltage Meters is very undesirable... I may have to look for a LCD (non-backlit) solution...
Two sets of per-cell leads.
Not using the batt, disconnect everything best cells are 100% isolated
Understood. Is it okay if i keep it as one 14S pack? I don't know if i have the skills to make two 7s ones that will fit in the triangle bag lmao :lol:
john61ct said:
14S balance charger is very hard to find these days
Agree but, I'm planning to use active balancer/bms instead of a balance charger (they're too expensive lmao)
=== NEG LEAD TO LOAD
:lowbatt: :lowbatt: :lowbatt: :lowbatt: :lowbatt:
8S LED Meter, 8S Active Balancer
50 A SHUNT CONNECTION ALWAYS ON
- POS LEAD TO LOAD
============================ 14S BMS
like so lol
