want to build
- Joined
- May 18, 2018
- Messages
- 291
HI i finally found a kit that has pure nickel with it.
i need to know if my bms will fit and where.
i have 52 cell (13s4p) and the case is made for 13s5p(65cell)
so MAYbE i can fit my bms in it the BMS is 12cm by6.5 cm by2cm.
WiCH cell emplacements should i not use to fit the bms and not create problem ??
see pic maybe use paint to put x on the cell emplacement to not use and show where it is intelligent to put the bms ?
tx model 48v and nickel here https://fr.aliexpress.com/item/4001366582546.html
