I keep seeing packs with an automotive fuse sitting behind a bms, and I wonder what's the point. Even in a pure redundancy scenario, a proper bms will trigger an OCP way before the fuse would melt, and die if the OCP fails. Even in that extreme case, the main discharge would be instantly cut off, so when exactly would the automotive fuse melt ?
Since a fuse adds some sort of resistance (though I agree: irrelevant in high power system), only reason I could see for such a setup would be to limit the output of a bms too powerful for a given controller. What do you think ?
