chronosgarage
- Joined
- Oct 23, 2020
- Messages
- 96
I need some help; I recently short my Votol EM100 controller. When the controller shorted, the battery is shut off by the bms (possibly by over current protection). The short cause 3 of my cell fuse in the battery to burned. I’ve check the 3 battery condition and found that it’s normal. I then replace the cell fuse in those 3 batteries.
The spec of my bms is 20S 45A (Common port) with 20S9P battery. The battery highest voltage difference Between parallel group is about 0.1v
My problem is the bms do not turn on. I’ve tried to charge it, but it cannot be charged. The is no visible damage on the bms. Is there any reset protocol that i need to perform? Or is my bms is damaged?
