I have a battery pack with common charge/discharge wires. Because the same wires are used for charging and discharging, I'm attempting to creating a way to charge my battery without unplugging it from the controller. I've attached an image of an idea I mocked up. If you can't see the image, here's my idea: If I connect the discharging wires to the terminal block on my controller and then also connect a new set of wires for charging (screwed on top of the terminals), can I safely charge my battery without harming the controller? If the controller is turned off, I don't see why there would be any problem. I have searched all over the internet but I cannot find a discussion or example of how this can work. I want to avoid splitting the discharge wire with a banana connector, its really not ideal.
