pic 1) daly BMS has 11 wires and the JST’s have 6, is this correct?. bottom Lipo is main negative and top is main positive, two 5s Lipos
pic 2) the BMS wires will be soldered to a JST adapter first. would it be safer to heat shrink the excess wire or remove the pin, assuming the first diagram is correct
