Build suggestions
TheSiege
Right no I have a scooter with a 21s3p gen 1 chevy volt pack which would be 45ah which I am sure us somewhat degraded to 38ah or so. I have actually not seen it, so I am unsure of the dimensions. but its in a woodbox that was custom made. The hub wheel is rated at 7kw
I want to make a new pack with at least 60ah. I am pretty sure I should be fine to go to 22s if needed. What would be the optimal choice for energy density and still be the same relative foot print? I can use whatever chemistry, I just probably need to keep it under 95v. Thanks
