Prius NHW10 (MK1) Hybrids - How to test and resurrect them
Mr. Mik   1 kW
Honda used the same sticks!
Post by Mr. Mik » Jun 11 2010 11:55pm
It turns out that the Honda Civic and Insight use the same subpack sticks as the Prius NHW10!
And there are others out there with much better equipment, knowledge and ability than myself to test them!
Check out this site (and all the other fantastic pages in there): http://www.99mpg.com/blog/batterypacksexpose/
And this forum: http://www.insightcentral.net/forums/mo ... eries.html
and http://www.insightcentral.net/forums/mo ... al-issues/
Back to my own little corner: I have started to make a sort of index of this thread in the first post at the top: https://www.endless-sphere.com/forums/v ... 14&t=12764
Mr. Mik
There is always a way if there is no other way!
The writer of this post accepts no responsibility or liability resulting from attempts to repeat or perform the procedures described in this post. This information may be used at your own risk.
Mr. Mik   1 kW
Panasonic Patent on how to do it.....
Post by Mr. Mik » Jun 12 2010 7:24am
Here is a patent by Panasonic which describes a method of detecting bad cells in long battery strings and replacing them.
It may be of some use, and many NHW10 owners believe it is about these batteries.
Matsushita-Panasonic advice re Prius NiMH battery US6573685.pdf
(1.3 MiB) Downloaded 629 times
Mr. Mik
Mr. Mik   1 kW
First real world EQ charge with Special Freddy 8.0
Post by Mr. Mik » Jun 12 2010 7:43pm
The Special Freddy 8.0 charger is now charging the battery in my Blue NHW10 for a preventative EQ charge.
It's been seven weeks since I placed the reconditioned battery (with one stick exchanged) back into the car. It was "bottom balanced" at the time, i.e. all sticks empty but just capable of starting the car once. The car then charged the battery up to wherever it saw fit.
The warning triangle has not come on again. The car is working perfectly.
There have been two occasions when the car started to charge the battery (by mildly revving the ICE) until the battery was shown as full on the Multi Function Display (MFD).
No turtles, no power restrictions. Battery SOC on MFD never dropped below 1/2 in 7 weeks of driving (at least I did not see it).
The battery has no wiring harness for external charging, yet. Therefore I had to take the seat out and open the battery cover.
It takes 30min to get to the start of actual charging, all hooked up and ready. Definitively an incentive to work on the battery-internal part of Special Freddy and install a harness! Too much hassle to do it this way every few months!
The earth connection is still a rigged-up part - the red alligator clip cable, that needs fixing! The connector for the gray cable coming from Special Freddy has plenty of empty poles for that, eventually the orange and grey cable will both terminate at the same single connector, so one cannot forget to connect some part or another.
The EQ charge is still running, here are the problems encountered so far:
The charger turned off the current twice and I cannot tell with certainty when it happened. That makes estimation of total EQ charge time difficult. After the first time, I added a DMM with Min/Max function. That way, I will have some indication how far it got. I also reduced the resistance of the trimpot by a 1/4 turn each time. Eventually it will be set low enough to never turn off unnecessarily.
And that's it as far as problems go!
Now to the unexpected good results so far:
The charge current turns off immediately if the car is turned on during charging! I do not quite understand how this works, but it does. That can only be good, unless you forget to turn it back on and stuff up the EQ charge. But usually one would avoid turning the car on during EQ charging.
Another (hopefully good!) result is that the master warning triangle and the Car with exclamation mark come on when the car is turned on with the charger attached and powered up. I expect this to disappear as soon as the PTC strip is reconnected to the stock system. If the warning symbol remains on, then this is of course a bad outcome. I will know in a few hours.
The ICE did start (I just had to try it!), but I did of course not try to drive with the charger plugged in!
I think it is essential to reset the EQ charge request warning symbol if a permanent EQ charge harness is to be installed into a good or reconditioned battery.
Otherwise the risk of someone attempting to drive off with Special Freddy connected would be very high.
The grid plug should also be connected in such a way that it gets pulled out clean if the car is driven off - automatic disconnect! :lol:
Mr. Mik
Mr. Mik   1 kW
DiPoD - Is the ICE burning Dino Poop right now???
Post by Mr. Mik » Jun 13 2010 5:55am
I used the extra time ("created" by the delay to the EQ charge) to finish a little project which I have had in mind since a while:
A visual indicator that says:"The ICE is burning Dino Poop".
Now, how do you turn that into an acronym....Hmmm......TIbuDiPoo????? ROTFLMAO
EDIT: Came up with "DiPoD" for Dino Poo Detector.....
Anyway , it works now!
I floated the idea on the Yahoo Prius MK1 group a while ago, and a number of ideas were proposed. I though this particular one was most likely to succeed; it was suggested by Peter R. the group "owner".
Today I finally tackled the job by having a look at the "Research Vessel" with a DMM.
Aim: Plug into the fuel pump power supply and hope that the fuel pump is always (and only!) on when the ICE is running.
I found 5 or 6 wires entering the plug on top of the fuel tank under the rear seat. One of them is white-black and I think that is the battery common ground wire. This might be the same as chassis ground when the battery is installed in the vehicle, but I am not certain about it. So I stay right away from it when I can!
Somehow most of the other cables looked like sensor wires to me (for fuel level measurement) so I decided to hone in on the black-red-black-red with silver dots wire.
I followed this wire towards the front of the research vessel - and after putting in a 12V battery and the HV circuit breaker I cranked the ICE and found 13.5V between this wire and chassis ground! BINGO!
While the blue NHW10 was finishing it's EQ charge, I searched in it and found the same black-red-black-red-silverdots cable under the plastic trim at the bottom of the driver door (amidst many other cables!). I measured the length of cable I would need, then soldered cables to a "12V LED courtesy light" (which I had snatched up for cheap at a Dick Smith "Get rid of all the interesting stuff sale" together with several bags full of other treasure), making sure the polarity is right. Then covered it with clear shrink-wrap to avoid any shorting and added hot-melt glue as needed. A ring-lug was soldered to the negative cable, then I fed both cables through the slot underneath the bonnet release lever. Next I bolted the negative lead to chassis ground together with all the other ring-terminals under the corner plastic trim. The positive cable was hooked up with an insulation displacing splice-connector to the black-red-black-red-silverdots cable midway underneath the plastic strip at the bottom of the driver door (not on the door, but between the seat and the lower "door-frame" so to say. I bet there is a proper name for that part of a car....)
Three cable-ties and a little bit of electricians tape later, it was all tied up and now looks like this:
It just sort of dangles there and the LED's intense light can be directed as needed for almost any lighting conditions.
The two different plastic panels mentioned earlier can be seen in this picture.
The results from a single test drive:
The LED's come on seconds before (and after) the MFD show energy flow from the ICE starting or ceasing. The time delay is gone, there is immediate feedback rather than waiting 2 seconds for the next MFD refresh.
So far, I have not been able to test the device with a cold ICE. I ran the ICE after completing the EQ charge and to test the new gizmo until it was warm enough to turn itself off while parked. The test drive followed this, starting with a warm motor.
But the results have already been very very interesting and I think probably very useful as well!
Mr. Mik
Mr. Mik   1 kW
Re: Burning Dino Poop right now??? Part 2
Post by Mr. Mik » Jun 13 2010 11:15pm
I had another very interesting test drive with my 07/1998 Blue NHW10 today, learning what it does by way of watching the "DiPoD" (Dino-Poop Detector).
It was most enlightening!
The drive started with a cold engine, which makes my 07-98 NHW10 behave differently from times when the ICE is being turned on when it is already warmed up.
I do not know if this is a malfunction or if Toyota changed the design / programming at some point in time, because my white 12-1998 NHW10 behaves quite differently!
The blue NHW10 will never stop the ICE if it is turned on and the car is left parked in "P".
The white NHW10 will run the ICE under the same conditions for about 5-10 minutes and then it turns itself off automatically. The white car will also turn the ICE off at traffic lights once the ICE is warm, even when the ICE was only started once when still cold.
The blue car, however, will not turn the ICE off at traffic lights, even when it is well and truly warm, unless the ICE is turned off and then on again when already warm. From then on it will continue to behave just like the white car and turn the ICE off at every occasion.
Before installing the DiPoD I could not determine if the ICE was running whenever the car was moving faster than about 20km/h due to road and wind noise.
I assumed that the ICE in the blue car would also run continuously while coasting downhill when the trip started with a cold motor, because as soon as I had slowed down enough to hear the ICE, I would always find it to be running. The DiPoD showed me that this assumption is incorrect!
I have not tried it out in the white car yet, so the following only reflects the behaviour of the blue 07-1998 NHW10 with DiPoD:
Even after a cold ICE start, the ICE gets turned off when coasting at speeds higher than 60km/h. If the shifter is changed to "N", the ICE starts to run immediately while the car is coasting. There goes my theory that coasting in "N" might increase km/l results!
When I let the car coast in "D", the ICE will stay off until the speed drops to 49km/h - the ICE starts to run each time when this occurs.
The ICE does not run when coasting at 100km/h, I will have to test higher speed on the highway sometime later.
When I turn the blue car off and on again with already warm ICE, then the ICE does not start any longer when coasting at or below 49km/h; it turns off whenever I take the foot of the gas pedal.
That insight alone was worth the effort of building the DiPoD - :lol: but wait, there is more....!!!! :lol:
It turns out that it is possible - contrary to what I have read somewhere - to use electric propulsion at speeds at least as high as 80km/h!
Because the DiPoD gives immediate feedback (rather than the 2-3s delay for the MFD) it is possible to give just the right amount of (feather light!) gas pedal action to add a bit of power to the glide without running the ICE.
Pulse and extended glide, so to say!
In practice this is going to be most useful on moderately downhill stretches of road, when drivers behind you are in a hurry and want to push you to drive at the speed limit. Depending on terrain this might make a significant contribution to km/l values!
Can anyone tell me if the different behaviours between cars described above are typical for NHW10's of a certain age or serial number? Or is it a fault that can be fixed somehow? Where in the electronic system is this behaviour stored or determined?
Mr. Mik
Mr. Mik   1 kW
Re: First real world EQ charge with Special Freddy 8.0
Post by Mr. Mik » Jun 14 2010 6:27am
Mr. Mik wrote:...
Another (hopefully good!) result is that the master warning triangle and the Car with exclamation mark come on when the car is turned on with the charger attached and powered up. I expect this to disappear as soon as the PTC strip is reconnected to the stock system. If the warning symbol remains on, then this is of course a bad outcome. I will know in a few hours. ...
The warning triangle and car with exclamation mark disappeared after three times turning the system on and off, without starting the ICE. I read somewhere that many error codes get cleared automatically if the fault does not recur during the next three drives.
So the unexpected safety-charger-shut-off and warning signal on dash when the car is turned on during EQ charging has had no deleterious effect at all. Nice! :D
Mr. Mik
Mr. Mik   1 kW
Soldering replacement cells into a stick
Post by Mr. Mik » Jun 14 2010 4:10pm
Attached is a PDF with photos of a individual cell replacement by soldering the cell in.
Here is what the person who sent it to me explained about the process:
You have my permission to publish them.
To avoid overheating of the cell you need a quick soldering. This is done easily using a strong soldering iron and soldering flux which is formulated to remove a film of oxides from the metal and make the solder and metal more able to dissolve in each other flux.
The current capability its ok but I don’t know if the internal resistance of the cell is suitable.
As I already mentioned I make the same cell replacement during 2007 and until now the modified module is working ok except of course from the continuously displaying in the centre display the "exclamation mark" within a triangle below the battery sign.
From the scanner I see that the repairing module has a little more voltage from
the other ones which is not affect the car operation.
The scanner is a Carman scanner.
Prius single cell replace jun10.pdf
(763.85 KiB) Downloaded 881 times
Mr. Mik
Mr. Mik   1 kW
HaloHA - Monitoring discharge with a DSO
Post by Mr. Mik » Jun 15 2010 6:57am
Here is how I measure the voltage and current during discharge of a complete NHW10 battery pack using a PoScope.
http://www.poscope.com/ (The basic kits do not contain the x100 probe which is needed for this setup!)
Do not attempt this if you do not have the necessary skills and experience! The voltages and currents involved are lethal and there is also substantial risk of causing a fire!
I do not yet know if a single reversing cell is detectable with this setup. But when I measure a NHW10 half-pack or a Vectrix 102s NiMH battery with a similar setup to the one shown, then I can easily spot an empty cell if it occurs during the flat part of the discharge curve. A single cell hitting empty is not obvious if / when it happens during the "Knee" in the discharge curve for the whole battery.
The discharged Ah capacity could be calculated by using a spreadsheet program and feeding the CSV log from the PoScope into it. I'll have to try that one day...
Click thumbnail for larger schematic: Image
Description:
The simple plug-in timer is used to automatically terminate the discharge, just in case I get distracted. I set the timer for a time that is too short to discharge the battery completely. The timer has an override switch, so that - if I am there to observe - the discharge can continue uninterrupted. If I am not there, it stops at a safe time.
The timer supplies power to a 12V DC switchmode power supply (SMPS), which keeps a System Main Relay (SMR) closed as long as the timer provides power. I use an SMR which I removed from another NHW10 battery, but it should also be possible to use one of the SMR's of the NHW10 battery which is being tested!
The two battery half-packs (HP1 + HP2) are separated by the mid-pack circuit breaker. The breaker is the last part to be connected, and the first to be disconnected. When the breaker is out, the battery is relatively speaking much safer. When the breaker is in, it is very dangerous.
On the negative output of the battery I connect a 10mOhm shunt.
Channel B of the oscilloscope measures the voltage drop across that shunt, i.e. 10mV/A.
The ground lead of the PoScope is connected to the battery side of the shunt and is also the reference for Channel A.
Channel A has a 100x probe connected, because the battery voltage far exceeds the maximum allowed voltage of the PoScope.
The load consists of pairs of resistive loads. I modified a power board so that its outputs are in series instead of in parallel. This is needed because the loads are rated for 220-240VAC, so they would not last long on 320VDC. It is however important to always have similar loads in series, or the weaker resistor will experience a much higher voltage and possibly burn.
Two halogen heaters with three individually switch-able 400W rated modules (HLG) make up the bulk load.
The switches on the halogen heaters are not capable of disconnecting DC currents! They arc and weld together. Turning it off is the job of the SMR!
A few lamps with inter-changeable incandescent globes (INC) serve to fine-tune the load as needed to achieve more or less current.
With all the loads switched on, about 6A will flow at the start of the discharge of a full NHW10 battery.
Between the PoScope and the laptop (running the PoScope software) is a galvanically isolated USB hub, just to prevent any dramas with ground loops or other rogue electrons frying my computer and data! :!:
The Halogen Heater Array (HaloHA) looks like this:
I have not been able to calibrate the PoScope in recorder function so that it displays accurate voltage for the battery or accurate current draw! For a NHW10 half-pack the measurements are OK, but for a full pack the voltage reads around 10V too high, and the current reads 2A too low.
This is not too important though, because the really important information is in the shape of the curve, rather than in it's level!
This graph shows a 6A (at start) discharge of a complete NHW10 battery (including the interruption by the safety timer):
The cells are either balanced, or the drop from a single cell hitting empty is too small to see.
This graph shows a 6A discharge of a NHW10 half-pack with a single cell dropping to zero V:
Mr. Mik
Mr. Mik   1 kW
My latest "BEST" NHW10 test method....
Post by Mr. Mik » Jun 19 2010 2:13am
EDIT 2010-07-07: This method is not my favourite any more....
I finally got the idea (and the experience) to put all my various pieces of equipment to work together for a "fast" :lol: and thorough NHW10 test method.
Core point: Replace capacity testing with the CBAIII with capacity testing with the AMPEASEL and PoScope monitor.
http://endless-sphere.com/forums/viewto ... 14&t=12032
This allows a high current test to be performed at the same time as the capacity test, but it is much faster, and also produces a graph (I like that because it is easier to understand a graph than the raw numbers, at least for me).
I also use the Special Freddy (SFreddy) charger and the Halogen Heater Array (HaloHA) in the process.
Step 1): Charge entire NHW10 battery with SFreddy to about 150% capacity.
Step 2): Discharge through HaloHA with PoScope monitoring and safety timer.
Steps 3 to 8 ): Repeat 1) and 2) three times, but less over-charging is needed, 120% is probably OK (12 hrs with SFreddy)
Step 9): Charge with SFreddy and leave to rest for 2 weeks to allow self-discharge to occur.
Step 10): Take half-packs out of the battery at some time during the self-discharge period.
Step 11): Test individual sticks ( while they remain in the HP's) with the AMPEASEL and PoScope monitor.
The whole process will take 20 days, but reduces the time that needs to be spent 1:1 with the equipment.
If you work full time with these batteries, then there might be better ways of doing it; but if you have a day job and other things to do, then this approach might be the most efficient one. It's certainly the best I've been able to come up with, so far.
The AMPEASEL test (Step 11) discharges the stick in one session at 100A, then 60A, then 25A (all approximate current), and each time to a cutoff voltage of 5.5V. It needs to be done closely supervised, see below graph for my blunder with being a littler inattentive - the cutoff voltage between step 2 and 3 is too low because I did not flick the switch in time!
Red curve: Stick voltage in V.
Blue curve: Current x 20 in A.
X-axis: Minutes
The sticks do get hot during this test, I've seen 70degC so far. Measuring the resistance of the temp sensor strip along the stick might be an additional way of gaining data about the stick, I'll try that when I get around to test the sticks in the HP's . So far, I have only tested this with sticks outside of the HP's.
Mr. Mik
MN Driver   100 mW
Re: Prius NHW10 (MK1) Hybrids - How to test and resurrect th
Post by MN Driver » Jun 19 2010 2:49pm
Although it might be a minimal effect to the cells in the end and might not matter much to you but pulling a 100 amp load and continuing with a large load is going way out of spec and possibly damaging these cells in ways that might not be immediately apparent.
The Honda Insight will pull 100amps but it won't do it for minutes at a time, it does it for about 10-15 seconds based on conditions such as battery state of charge and won't even do a full 100 amps unless the temperature is low enough.
The Panasonic HHR650D cell maximum continuous discharge specification is 32.5 amps (5 times their test discharge Ah rating)
I like to keep them under 50 degrees as much as I can and if I were doing the levels of current you are I'd be doing everything I can to keep them cool or at least a decent box fan, if not a blower aimed at them on full speed. I've pulled these cells off of a charge at 50 degrees and watched them climb over the next 10 minutes to 55 degrees. They are hotter inside than they are on the outside, especially with added cooling so keep in mind they might be 70 degrees right after the discharge but what were they 10 minutes later? Have you checked?
I don't think waiting 10-15 minutes is a long time to discharge a stick in the 30 or less amp area, but you've likely got different priorities.
My 2 cents, take them for what you feel they are worth.
Mr. Mik   1 kW
Post by Mr. Mik » Jun 19 2010 4:50pm
MN Driver wrote:Although it might be a minimal effect to the cells in the end and might not matter much to you but pulling a 100 amp load and continuing with a large load is going way out of spec and possibly damaging these cells in ways that might not be immediately apparent.
Excellent points, thank you!
So far I have only done this a few times to two sticks, a good one and a bad one with high self discharge rate.
I have already been pondering something similar to what you said overnight, and woke up with a new plan brewing in the back of my head:
1) Discharge at 100A for a brief time - until the curve goes somewhat flat, or the voltage drops too far, or a certain time has elapsed. Basically do it long enough to seeee if the voltage collapses under the load or if it holds.
2) Switch to about 50A (I'll adjust the AMPEASEL) when any of the termination points have been reached in above point 1). Then switch to step 3) when the peak in voltage has just passed. (You can see in the discharge graph that the voltage recovers from the 100A discharge for about 20s before beginning to fall again).
3) Discharge at about 32.5A (I'll adjust the AMPEASEL accordingly) until 5.5V cutoff is reached.
It will take slightly longer, but not much. It will still incorporate the 100A test, but limit the heating. The drop from 100A to 50A should make the peak more pronounced and give a clear indication for when to switch to 32A. I would like it to be "repeatable" so I can compare results and reliably identify bad sticks. Maybe I'll get rid of the 50A stage altogether, need to experiment a bit more.
Re: the heating after charging and discharging: There are several factors at play:
A) The cells do not necessarily heat evenly, sometimes there are hot spots. If you measure a cool spot, you get more temp rise after the test. If you measure at a hot spot, you get temperature drop soon after the end of the discharge.
B) The absolute temperature of the cells. Above some point the heat transfer to the environment is so high that the temperature falls soon after the end of discharge. At 60-70degC the temperature seems to peak within 2-3min after discharge or earlier, then falls rapidly.
C) Charge or discharge - after charging the temperature rises for much longer than after discharging.
Mr. Mik
Mr. Mik   1 kW
Post by Mr. Mik » Jun 19 2010 6:44pm
Here is the version I arrived at at the workbench:
Image Click to enlarge.
100A for 1 minute, followed by 32A until 5.5V cutoff.
Temperature stays below 50degC (only just, when starting belo0w 30degC and in ambient temp of 18degC) and temp opeaks at 1min after end of discharge.
The testing of two half-packs can be done in a single weekend day at this rate. With the CBAIII it would take an entire weekend.
Later today I will tackle a HP in this (or a similar) manner.
Of course, it might turn out that after 2 weeks of self-discharging I need to change the approach - the above tests were done straight after charging!
Detailed temperatures (by IR thermometer):
Max cell temp at time (DegC):
0 min: 21.8 = Stick temperature before test.
1min: 34.0 = Stick temp after 100A test:
2min: 35.1
3min: 36.4
4min: 37.8
5 min: 39.2
6min: 40.8
7min: 41.9
8min: 43.5
9min: 45.4
Turned off.
10min: 47.3
11min: 46.4
12min: 46.4
13min: 45.8
Mr. Mik
Mr. Mik   1 kW
HP1 AMPEASEL Test
Post by Mr. Mik » Jun 21 2010 7:05am
Here are the results of the first Half-pack (HP) of battery NHW10-02 tested with the Ampeasel.
General AMPEASEL test procedure:
Reduce current or terminate test at any time if the curve looks like the stick is not coping
1) Turn on recorder (PoScope)
2) Start at full load, ~ 100A
3) Switch to ~30A after 1min of discharging.
4) Switch off when 5.5V cutoff voltage is reached.
5) Measure resistance of Temp Sensor Strips with max recording for each stick (results not shown, they were very unspectacular! The best sticks show a rise from 1 Ohm to 1.8 or 2.0 Ohm; poor sticks show no rise because less energy is dispensed in the discharge)
6) Wait for the voltage to rebound and flatten out (some of the most interesting details can be in that part of the curve!)
This battery had been removed from a Prius 1-2 years before I got it (about a year ago). It was "charged up" occasionally with the booster charger included in the NHW10 Prius (by the previous owner). As far as I know, this does not fully charge the battery, only brings it up to enough SOC to kick the ICE over. I let it sit for 6months or so, uncharged.
In mid December 2009 I opened the battery up and measured voltages:
Entire open : 273.3V
HP1 open: 134.8V
HP2 open: 138.4V
I charged the battery very slowly (5 days) just once (using Universal Freddy, a charger similar to Special Freddy, but it has 4 different switch-able motor run capacitors to make current adjustable).
This was in preparation for buying my first Prius NHW10 (the blue one) off ebay. I won it, dropped the battery into the car and drove it until early March 2010 without apparent problems. The warning triangle was permanently on - it stays on even if the battery is perfectly good. It can only be reset with a Toyota S2000 scan tool.
Then, in early March I got some indications that the car was trying to charge the battery by revving the ICE slightly higher than usually, and then a single "turtle" (a turtle shaped LED on the dash, meaning "Go Slow" or something like that).
I repeated the EQ charge, this time in the car and over 2 days, which fixed it all back to working well. Another week later I repeated the EQ charge to test the wiring harness I had installed by then, adding in a variac to boost the voltage. It all worked well.
I drove the blue Prius for another week or so (without any apparent problems), and then I parked it in the sun for about 3 to 4 weeks. The first week or so without a cover, the last two weeks with a white car cover. All of this in Australian Summer heat conditions.... I had just bought another two NHW10 Prii and was busy with them, and with analysing and repairing the battery that had come with the blue car, the one I called "Dead as a Dodo?? Dying Swan or Phoenix?" battery mentioned above. Once I had restored the original battery by replacing a single bad stick in it, I put it back into the blue car; no more warning triangle since then (due to the original B-ECU installed with it - it does not have the warning triangle stored!).
It was on April 24th that I removed the NHW10-02 battery from the blue car and started a stick-level capacity test on April 26th, named the CBAIII Test 1 below; done at 12A to 5.4V cutoff level.
The results were all over the place! They do not correlate with the later test results, except for the worst stick of them all - that one was bad in all three tests (but only HP1 finished testing so far).
Then I charged both HP's once on the bench and let them sit for three weeks, before the CBAIII Test 2 (also at 12A to 5.4V cutoff).
Because the results were so different from the first test, I cycled the HP's 5 times on the bench (whilst improving the method for detecting a single reversing cell) and then let HP1 sit for 2 weeks in the cool garage to self-discharge. HP2 is up for the Ampeasel test next, in a few days time when it has also rested 2 weeks.
The results of the first CBAIII capacity test (after 3-4 weeks of standing in the car in the heat) are given below together with the results of the second self-discharge test with the CBA III and with the graph showing the result of the third (Ampeasel) self-discharge test done yesterday. This helps to show if the high current Ampeasel test is actually helping, and if the 5 x cycling has helped!
Red curve: Voltage in V
Blue curve: Current in A x 20
X-axis: time in h:min:sec:msec
The sticks were not tested in the Ampeasel test in the order shown below. Instead, I started at the top of the pack to reduce the heating up of untested sticks from the discharging sticks below them.
Stick 1 = negative end of the pack.
Stick 20 = positive end of the pack.
Stick 01:
CBAIII test 1: 1.956Ah; good curve.
CBAIII test 2: 4.642Ah, good curve
AMPEASEL test: A good one:
Stick 02:
CBAIII test 1: 1.876Ah, good curve.
CBAIII test 2: 4.519Ah, good curve.
AMPEASEL test: Another good one ( I forgot to turn the PoScope monitor off before disconnecting the cables)
S03:
CBAIII test 1: 0.960Ah; good curve. (That's one of the inconsistent ones!)
CBAIII test 2: 4.064Ah, good curve.
AMPEASEL test: Another good one:
S04:
CBAIII test 1: 1.214Ah, good curve.
CBAIII test 2: 4.088Ah, good curve.
AMPEASEL test: I stuffed up! Instead of turning to 30A at 1min, I turned it off! But a good stick, nevertheless.
S05:
CBAIII test 1: 1.021Ah, good curve.
CBAIII test 2: 4.084Ah, good curve.
AMPEASEL test: Another good one.
S06:
CBAIII test 1: 1.194Ah, good curve. (One of the inconsistent ones)
CBAIII test 2: 0.105Ah, early drop, bad cell? Stopped manually.
AMPEASEL test: A very very marginal stick! Note the steep drop towards the end of the 1min @ 100A phase. It recovers briefly, but the weak cell in the pack empties after a brief time at 30A. Because I terminated the discharge very soon after the obvious end of the fall in voltage at 1min:40sec (= a single cell has finished falling to zero V), there was a smooth immediate rebound in the overall stick voltage. The cell which dropped to zero volt bounced back up to around 1.1V immediately.
S07:
CBAIII test 1: 1.104Ah, good curve. (inconsistent with the two others)
CBAIII test 2: 0.02Ah, very early drop, terminated manually. Bad cell!
AMPEASEL test: Similar to S06: It just manages to hang on for 1min @ 100A, with a steep drop at the end. Then, early in the 30A phase, a single cell in the stick drops to 0V. But this time, I let this continue for about 45sec. The result of this 45sec reverse charging event (is it that, strictly speaking?) is the kink in the recovery curve after the end of the discharge, at about 2min:25sec. The sudden rise by about 1V is caused by the recovery of the weak cell from around 0V to around 1V. The longer it was reverse charged, the longer it will take to bounce back up. If it was for too long, it would never bounce back!
S08:
CBAIII test 1: 1.805Ah, good curve.
CBAIII test 2: 0.072Ah, good curve.
AMPEASEL test: I stuffed up the recording...forgot to save it! Cell reversal during 100A. Did not recover when switched to 30A at about 40sec; delayed voltage recovery of single cell after turning off (like with stick 07); Switched off early due to cell reversal.
S09:
CBAIII test 1: 1.588Ah, good curve.
CBAIII test 2: 2.183Ah, good curve.
AMPEASEL test: A good stick, but clearly less capacity than the best ones.
S10:
CBAIII test 1: 1.782Ah, good curve.
CBAIII test 2: 1.195Ah, good curve.
AMPEASEL test: A marginal stick. Copes OK with the 100A phase, but the 30A phase is only abot 2minutes long. After the discharge, it recovers to over 7.7V! This is due to the majority of cell in the stick still not being anywhere near empty. Just one cell hit empty (t 3min:20sec), and once it bounces back up to 1V, the remaining charge in the other 5 cells brings the resting voltage up higher than it would be for a good stick which has been able to discharge most of it's energy.
That will have to do for this post, the forum software will not allow more than 10 pictures per post!
Mr. Mik
Mr. Mik   1 kW
Special Freddy NHW10 EQ V 10.9
Post by Mr. Mik » Jun 29 2010 3:17pm
I'm working on an improvement to the Special Freddy charger.
My first Op-amp project, thanks to help and inspiration received from Mike Dabrowsky here: http://www.insightcentral.net/forums/16 ... st534.html
By adding a LM324N and a number of LED's the over-temp shutdown should get much more reliable than the relay method I used so far and give an easily visible indication of what is going on. I plan to install the LED's so that they illuminate the voltmeter and ammeter during operation.
The LM324 is used s a voltage comparator and switches it's output high or low with trigger-like accuracy, unlike the drop-out voltage in my previous design.
I should be able to set a warning temperature of, say 40degC, and a cutoff temperature of 45degC with good accuracy. The previous design was only able to shut down the charge current with severe battery over heating. The new design should also resume charging once the temperature falls to the set levels again!
The diagram below is still full of errors!
Mr. Mik
Mr. Mik   1 kW
AMPEASEL III testing NHW10-03
Post by Mr. Mik » Jul 06 2010 4:12pm
I have now tested the individual sticks in the battery I call NHW10-03, mentioned in the post https://www.endless-sphere.com/forums/v ... 73#p279315 above.
The results of the individual stick tests (below) show that the sticks are nicely balanced with regard to their capacity under a 30A / 100A / 60A / 30A discharge.
I am quite certain that also translates into very similar capacities at the 6A discharge applied (above) earlier to the whole battery.
So I still don't know if a single cell in the 240s battery can be spotted dropping to zero V on the PoScope graph! But I have another good battery......or do I?
That is my question here: Should I replace the sticks with greater voltage drop under load, although they are not much different from the great majority of sticks in the pack with regard to Ah capacity?
Please have a look at the discharge graphs below and let me know what you think: Should I take the 3 or 5 weakest sticks out?
The pre-test preparation of the NHW10-03 battery:
A) 4 complete charge (@~0.6A) and discharge (@ ~ 6A) cycles
B) Another complete charge @ ~0.6A
C) 2 weeks rest for allowing self-discharge to occur (@ ~ 17degC on garage floor).
The AMPEASEL III test applied to each individual stick while remaining in the half-pack (quoted below are my own prompts for note taking and procedure during the test):
AMPEASEL III Stick Nr:
Ambient temperature (degC):
Set AMPEASEL to 30A.
Start timer and PoScope together. Wait 15sec.
Start AMPEASEL at 30A load. Cutoff level: 5.5V
At 1min switch to 100A for 15s, then back to 60A. Cutoff level for 100A test: 4.2V
Discharge at 60A for 15sec. At 1:30 switch to 30A. Cutoff voltage for 60A test: 5.0V
Stop discharge at 5.5V cutoff level.
Continue logging to recovery of all cells.
Turn off at 10:00
Total time (min:sec):
Following this procedure I get a set of very comparable graphs. I have not figured out how to overlay them into one picture, but viewing them with a picture viewer program sequentially shows the differences very nicely.
Here is a group of very good stick test AMPEaSEL III results from the first half-pack of this battery - no poor cells in there at all:
(Red curve = Volt; Blue curve = Ampere x 20)
Stick 1:
Stick 02:
Stick03:
Stick 04:
Stick 05:
Stick 06:
Stick 07:
Stick08:
Stick 09:
The slightly weaker sticks will be shown in a later post, only 10 are pictures allowed per post.
Mr. Mik
Mr. Mik   1 kW
Re: AMPEASEL III testing NHW10-03 Part 2
Post by Mr. Mik » Jul 07 2010 2:25am
Continuing the individual Stick test AMPEASEL III routine on the NHW10-03 battery:
Below are the graphs for the best stick S17 and the worst stick S35:
S35 has both the lowest Wh value, highest IR and lowest Ah value, but it does still cope with the AMPEASEL III test, and the Ah capacity is roughly 95% of the Ah capacity of the best stick! It's the worst stick in the pack, but definitely not dead!
Here are the graphs for the other 4 sticks which are slightly weaker than the rest of the pack:
S34:
S31:
S30:
S27:
The remaining vast majority of sticks are very similar to the good ones shown in the post above, sticks 1 to 9.
My impression is that the best stick is insignificantly better than the bulk of the sticks in this overall good battery, while the worst stick is bordering on being an outlier - but an outlier that is still coping at this stage.
Do you think it is worth the effort to replace the weakest stick(s) out of this battery?
Unless someone has experience showing that this will be a problem, I would tend to leave the battery untouched for now and use it. I might have another look in a year or more, or whenever the battery "plays up" - it should then show if the weak sticks have deteriorated to a more severe degree than the others.
Mr. Mik
Mr. Mik   1 kW
Post by Mr. Mik » Jul 08 2010 3:16am
I learned something new today: How to use a spreadsheet program (at least a little bit!).
Below is the result, an overlay of the voltage vs time discharge curves of the 6 best and the 5 worst sticks in the NHW10-03 battery. The program cannot handle all 40 sticks.....pffff...
Imagine the remaining 29 good sticks squeezed into the small gap between the groups of 5 and 6 graphs, and you will be able to see that stick S35 is indeed an outlier.
Seeing it like this makes it more tempting to replace S35!
Maybe I'll spend some more time with the spreadsheet program and work out how to calculate the area under the curve, V x I etc to get Ah values and Wh values! But that is really not a priority at the moment.
I'll try to determine exactly how impared the S35 is, by running a "AMPEASEL IV" test procedure on the two worst sticks and two good sticks.
AMPEASEL IV will consist of repeated 100A bursts on top of 30A base load spread across the entire SOC range. See http://www.insightcentral.net/forums/168737-post85.html for more detail.
Mr. Mik
Mr. Mik   1 kW
Testing NHW10-03 Part 3 - conclusion
Post by Mr. Mik » Jul 16 2010 5:36am
I learned some more spreadsheet basics and this has shifted my final assessment to "replace the worst stick" in NHW10-03.
Now I can make graphs showing Amp, Watt, Volt from the same data set gained during the AMPEASEL test.
Here is an overlay: Three ways to compare the same two sticks being discharged:
I can also use the spreadsheet program to "calibrate" the PoScope data. Unfortunately the PoScope lacks a calibration feature (or I, and the technical support guy, have not found it yet).
For example: (X + 0.018 ) x 1000 gives me calibrated current in amps (with the mV measurements across the shunt as the X value)
I can also add up all the current and voltage measurements every 0.6s - that gives the Wh which have been discharged.
And the ampere/0.6s can be added up to give an accurate Ah value for the discharge (just divide it by 6000).
The result of it all is this:
Stick 35 is significantly worse than the second-worst stick. It is very interesting to look at the Ah and Wh results. The Wh results are more dramatic, because they include both (reduced) capacity and (increased) internal resistance in the result.
If one was using a constant current discharge device, then this might not matter. But with a resistive load these calculations are very important to get the full picture.
After two weeks of self-discharge:
The best stick S17 had 5.34Ah and 34.55Wh.
The worst stick S35 had 4.96Ah ( = 7.1% less than best) and 30.42Wh. (= 11.95% less than best)
The second-worst stick S31 had 5.1Ah (5% less than best)and 31.89 Wh ( =7.7 % less than best).
S 35 had 2.6% less Ah than S31.
S35 had 4.6% less Wh than S31.
And that is what made me change my mind.
Being almost 5% behind the second-worst stick (Wh) is a clear indicator that S35 is indeed an outlier. S35 would in my opinion fail much much earlier than the rest of the pack, if it continued to be used in this pack. S35 will last much longer in pack matched to it's IR.
I have replaced S35 with a stick from another battery, it appears slightly better than the best sticks in NHW10-03 on an AMPEASEL IV test.
The test looks like this:
S35 (weakest stick of the whole battery):
S36 (good one):
If this test is done after a few weeks for self-discharge testing, it test all the major parameters of battery performance across the whole SOC spectrum.
But, it has not added anything that the earlier AMPEASEL test has told me (the one with 30A-100A-60A-30A sequence). But it requires more operator attention and input.
Mr. Mik
Mr. Mik   1 kW
Re: Testing NHW10-03 Part 3 - conclusion
Post by Mr. Mik » Jul 17 2010 5:24pm
Accidental double posting deleted.
Mr. Mik
paulmanta   1 µW
Post by paulmanta » Jul 19 2010 6:17am
I've just posted in the 'wants' section for a stick of the cells these batteries contain...
http://endless-sphere.com/forums/viewto ... =8&t=19973
Any ideas ?
Mr. Mik   1 kW
Scanner error codes
Post by Mr. Mik » Jul 24 2010 12:44am
Error Codes which can be read with some scanners (like the Carman Scan Lite and Toyota S2000).
PriusCodes1.pdf
(2.19 MiB) Downloaded 546 times
I think I found this in one of the Prius forums.
Mr. Mik
Mr. Mik   1 kW
Battery too damaged for EQ charge alone
Post by Mr. Mik » Aug 08 2010 4:52am
Here are the results from testing the NHW10-06 battery which came with one of the cars I bought. It is an example for a battery that is too damaged to be pampered along with EQ charging.
Initially I just applied a single EQ charge with the battery in the car, but after just 4 days the frequent turtles returned.
A few weeks later I did 5 complete EQ charges and 4 discharge cycles to exercise the battery, also with the battery still in the car.
That had a slightly more lasting effect, but after 10 days the turtles were back, accompanied by frequent Battery Low Point Resets (BaLPoR = sudden drop of displayed battery charge level to low, together with turtle, and followed by charging of the battery to near full display.)
The fourth of the discharges (at about 7A) looked like this:
Red: Volts x 100
Blue: Ampere x 3
The first three discharges looked very similar - they were all done just after charging. I still do not know if a single cell dropping to zero Volt would show up in the discharge graph of a 240s string.
After three weeks I removed the battery from the car and gave it an EQ charge in the garage, using the SFreddy charger for 13h:15min. In retrospect, that might have been a bit too short because of the severely increased self-discharge rate of some cells. The cells with the highest self-discharge rate might have been empty at the start of this EQ charge and might not have filled up to 100% SOC. But it does not matter much - the good cells were definitively full and no good sticks would have been misdiagnosed in the following tests.
After two weeks of resting at about 18degC on the garage floor, I removed the half-packs from the battery and tested each stick with the AMPEASEL III procedure.
AMPEASEL III = 45s at 30A-32A; then 15s at ~90A - 100A; then 30A - 32A until 5.5V cutoff.
Excel does not seem to be able to handle showing all 40 graphs at once, so I grouped them into three overlays. (I forgot to save the data for Stick 34. It falls into the "Medium" category).
The Worst Sticks out of NHW10-06:
The Medium Sticks out of NHW10-06:
The Best Sticks out of NHW10-06:
Now I have some sticks with definite problems and may be able to figure out how they could be detected without lengthy testing!
Mr. Mik
Mr. Mik   1 kW
Post by Mr. Mik » Sep 03 2010 6:45pm
I added a link to nice measurements of the PTC strip performance to the above post https://www.endless-sphere.com/forums/v ... 64#p189795
The addition:
Mike Dabrowski has done much more accurate measurements, the results can be seen here (in degF): http://99mpg.com/Data/resources/downloa ... ance-2.pdf and are explained here: http://www.insightcentral.net/forums/mo ... post172411
Mr. Mik
Mr. Mik   1 kW
Prius NHW10 (MK1) Hybrids - Fuses for tab wires
Post by Mr. Mik » Sep 11 2010 7:22pm
The end plates on one side of each half-pack (HP) have 11 tab wires coming out.
These seem to be fused by 11 built-in fuses. They can stand 3.6A for a few second - but I don't know what their proper specifications are.
The 11 fuses can be seen in this photo:Image
I'll try to find a better picture later on.
Mr. Mik
Mr. Mik   1 kW
Prius NHW10 (MK1) Hybrids - Techno S2000 Scanner
Post by Mr. Mik » Dec 20 2010 8:40am
The Techno S2000 scanner is the only scanner that can perform all necessary operations on a NHW10 Prius if the NHW10 data disk is inserted into the S2000.
Quite a few S2000, some with the NHW10 data disk, have recently been bought by private NHW10 owners. It seems like Toyota Japan is selling off the S2000, maybe they have a new device to replace them now.
The display of a typical S2000 is in Japanese. This can be a challenge, because the menu structure/content is complex. The S2000 includes DMM and oscilloscope functions as well; try to imagine figuring that out in Japanese....
Well, that's what this post is about. Much of the translation work has already been done, but there is more to be done. Many thanks go to a small group of NHW10 and S2000 owners in England, Australia and New Zealand, who have helped greatly to work out how the S2000 works and how the menus translate.
Some scanners, like the Carman Scan lite, can do most, but not all functions of the S2000, notably excluding the C2579 reset (="Uniform Charge Request").
Attached are two files with incorrect file extensions. For the first one the extension needs to be changed from .pdf to .mmp in order to work (this gets it past the forum software.) It is a "MindMan Personal" file showing the menu structure of the S2000(NHW10) in English.
The other attached file is also misnamed to get it past the forum software: Replace the .pdf with .exe and you will have a working installer program that will install the MindMan Freeware on your computer. This allows you to view the other file, the mindmap showing the English S2000 menu structure.
Newer versions of Mindmanager software are MUCH more sophisticated and capable, but they cost a packet. Using this very old and basic freeware version will allow anyone to contribute to developing the S2000 English map further.
I hope to soon publish a S2000 Menu map which can be viewed with a free viewer software application. It will be much more user-friendly than the MindMan Personal map, but it will not be editable by anyone without the full software version. It's similar to Adobe Acrobat (expensive, creates files) and Adobe Reader (free and read only).
Techno S2000 ENGLISH 1.6 2010-12-20.pdf
Rename this to Techno S2000 English 1.6 2010-12-20.mmp
(126.43 KiB) Downloaded 221 times
mmpersonal30-2e.pdf
Rename this to mmpersonal30-2e.exe
(870.82 KiB) Downloaded 173 times
Mr. Mik
